Down a front brake on one of our bikes so need either a new brake or pads for Avid...
Any thoughts? Heading out to ride at Brechfa or Nant Yr Arian so in either of those directions.
Clive Powells in Rhyader will be on the way to Nant, if its open.
Also
In Aberystwyth Summit Cycles should be open. (Nant direction)
In Carmarthen Hobbs cycles might be open (Brechfa directin).
But both of those will need a detour.
No one will be open today I'll wager.
we're open! 😆 a long way from wales though.ill get me coat...
Biped Cycles in brecon should be open till 4pm, you can ring the shop to make sure on 01874 622296. Little bit out of your way though
Summit Cycles in Aber won't be open as they are shut on Sundays normally anyway. Not sure about Clive Powells but worth a try if you are going past.
