narrow/wide chain r...
[Closed] narrow/wide chain rings. Any benefits for single speed?
Or unnecessary?
Race Face blurb states, ideal for 9/10/11 speed.
Posted : 06/10/2013 11:36 pm
is there enough slack in your chain for it to jump off?
Then yes, if there isn't (as a singlespeed should be) then no
Posted : 06/10/2013 11:43 pm
That's what I thought
Posted : 07/10/2013 12:10 am
Just want to resurrect this thread for a bit of clarification.
I'm thinking of SS my 16" Inbred. It doesn't have a slot dropout it is the geared variety.
SS tensioners look crap so does anybody know if I can get my chain tight enough for it not to come off without a tensioner or know if a N/W chainring would also allow me to not use a tensioner.
The way I see it( but could be wrong) a clutch mechs main use is to stop the mech moving forward, similarly, in the same way a single speed cassette doesn't move forward.
What other option is there to a tensioner? Half links? If I've got to have something hanging off the back end it may as well keep the mech and stay geared.
Posted : 11/04/2014 5:35 pm
I'm sure someone posted a tool somewhere which allows you to select a perfect chainring/sprocket combo for each chainstay length.
Posted : 11/04/2014 5:54 pm
You may be able to get the chain tight enough in a stand, but it will stretch so will become really loose quite quickly and you won't be able to tighten it.
I reckon for the cost of a nw ring, a few links and the time taken to fit it and bugger about with the chain tightening it to 'not quite tight enough', you could buy a sh inbred with horizontal dropouts....
Posted : 11/04/2014 5:55 pm
Yeah I was thinking the same about a slot dropout Inbred. Was trying to avoid buying the same frame three times( I had a 18" Inbred before).
Posted : 11/04/2014 6:41 pm
