narrow wide chainri...
[Closed] narrow wide chainring-bash guard or not
as above, is a bash needed, ride natural trails around peaks, lakes and hebden
Posted : 25/01/2014 10:52 pm
Depends what purpose you are using the bash for...do you need it to help keep the chain on? Then generally no. Do you need it to protect the chainring from knocks? Then yes
Posted : 25/01/2014 11:49 pm
For XC/Trail/AM/ whatever you want to call it, the main issue for me is knocking unprotected teeth off a chainring. I used to run a bash with 2x9 but it's not really an issue if you're running 1x10 since the chain is always there to protect the ring. Obviously a bash will protect against bigger impacts but for the odd scuff I don't bother with the added weight.
Posted : 25/01/2014 11:54 pm
