my on one just arri...
[Closed] my on one just arrived (celebrates) but i need some advice on worne old parts?
i found a seazed headset...which know works...its as rough kerry kotona but it works. how long do u think itll last in south wales?
i also have a cassette and chain...im judging the wear on the chain on the cassette wear...they were used together for a year and a half.
so will this cassette work? (pictures below)
[img] http://www.flickr.com/photos/25766926@N07/3929008971/ [/img]
[img] http://www.flickr.com/photos/25766926@N07/3929783448/ [/img]
Posted : 17/09/2009 8:37 pm
why dont my photos work?
Posted : 17/09/2009 9:01 pm
 Davy
If the cassette and chain have only been used together they should be ok, as long as the chainrings are the same age. Otherwise you'll need to replace the whole lot (probably).
Headset? Grease the bearings and see how it goes. At worst it'll come a bit loose or seize up.
Posted : 17/09/2009 9:19 pm
ok...i bent all the chain rings on a big rock...so im using newer onse...
Posted : 17/09/2009 9:20 pm
 Davy
There's a very vague chance that they'll work ok, but a much bigger chance that the chain will just skip under pressure, in which case you'll need to replace the chain and cassette, (after you've extracted yourself from the stem/scrotal interface that inevitably occurrs).
Posted : 17/09/2009 9:24 pm
