my "FREE"...
[Closed] my "FREE" gift to the world (mudguard template 100mm forks)
Simply printout the below so the measurements match.
place template onto an old inner tube and cut out.
you'll also need 4 zip ties to secure the mudguard onto your forks.
post your pics once done ๐Ÿ˜‰
Posted : 05/05/2011 8:59 am
POIDH
Posted : 05/05/2011 9:03 am
bloody miserable lot...wish I'd not bothered ๐Ÿ™„
Posted : 05/05/2011 11:00 am
I usually just use a rectangle with holes in each corner, 2 zip ties onto the brace, 2 onto the crown. What does that funny shaped thing do that mine doesn't?
Posted : 05/05/2011 11:02 am
it makes you go faster....Obv. ๐Ÿ™‚
Posted : 05/05/2011 11:04 am
Well I think it's a very nice helpful thing to do.
I like the little Stanley knife in the corner.
Posted : 05/05/2011 11:05 am
the shape is just through cutting a little off here & there until it fitted my sid's
Posted : 05/05/2011 11:12 am
dude this is great. Although I don't have 100mm forks.
Posted : 05/05/2011 11:14 am
if I had the measurements between the brace & crown of 120/130/160 I'll add them too ๐Ÿ˜‰
Posted : 05/05/2011 11:20 am
I can't visualise how it goes on a fork. Where do the 'ears' go?
currently, I'm using old ice-cream tub cut to shape and held on with two cable ties instead of inner tube.
Posted : 05/05/2011 11:49 am
sefton, I'll measure my 140/160/180 and 203mm forks
Posted : 05/05/2011 11:52 am
Nice idea but didn't work for me
My printer jammed when I fed my inner tube in
Need a new printer now, would have been cheaper to buy a neoguard ๐Ÿ˜‰
Posted : 05/05/2011 11:54 am
you wrap the "ears" around the brace a few times (from the front over to the back) then wrap the bottom around the crown (from the front over to the back)
I'll try and get some pics
Posted : 05/05/2011 12:02 pm
try not to chop your finger off with the knife too!
Posted : 05/05/2011 12:03 pm
 SiB
anyone got any pics of their innertube mudguard mounted on forks? I'm assuming it stops water/mud coming off the front tyre at that 45degree angle that sparays back in your face? Crud catcher still needed though for spray on to underlegs?
Posted : 05/05/2011 12:05 pm
๐Ÿ˜†
underlegs
โ“
Posted : 05/05/2011 12:10 pm
...there's a dim light starting to glow above my head...
Posted : 05/05/2011 12:23 pm
I'll get some pics ๐Ÿ˜‰
the "ears" wrap around & under them selves if that makes sense? then pop a zip tie through the hole & over the ears and around
Posted : 05/05/2011 12:26 pm
 5AM
I think it's a great template, my effort was definitely a lot more "botch" than this ๐Ÿ˜ณ
Posted : 05/05/2011 12:29 pm
or, make a rear-facing [s]crown[/s] (sorry, BRACE) fender from an old race number.
only about 1000 times better than a bit of old inner-tube flapping around your tyre.
Posted : 05/05/2011 1:14 pm
hello ๐Ÿ˜‰
Posted : 10/02/2012 2:17 pm
Sounds heavy
A rectangle with holes in each corner on rs sids 100mm here !
Posted : 10/02/2012 2:21 pm
Hats off to you Sefton - but I have a little red cross in a box, can't see it working ๐Ÿ™‚
Posted : 10/02/2012 2:28 pm
 JoeG
Thanks for the nice template Sefton. Unfortunately, it is wider than the tube I have available. I run tubeless, so I guess that I'll have to get an old tube from a friend that runs 2.5s or something.
Posted : 13/02/2012 8:52 pm
 Taff
How much drag is that going to cause?!
Posted : 13/02/2012 8:54 pm
still waiting on those photos of it in action to help explain the ears... ๐Ÿ™‚
Posted : 13/02/2012 8:56 pm
