MX Pro Travel adjus...
[Closed] MX Pro Travel adjustment?
3 Users
Anyone know if this is possible?
I want to drop from 105mm to 85mm.
Failing that anyone want to swap some 2005 MX Pro's for either something more modern/shorter or some 85mm equivalents?
Posted : 29/03/2011 8:26 am
Have a look in the top of the forks, if theres a 20mm plastic spacer in each leg then you should be able to do it (it may be above or below the spring)
Posted : 29/03/2011 8:28 am
If it's got an ETA lever then no, not without replacement internal's
Posted : 29/03/2011 8:31 am
It's ETA 🙁
Air spring and rebound adjuster on one leg, ETA on the other.
Posted : 29/03/2011 9:44 am
An email I got from Windwave when I asked about this: [i]to reduce the travel of the MX Pro to 80mm will require a new shorter travel ETA cartridge + spacers for the non ETA side, [/i]
Posted : 29/03/2011 9:55 am
