Mudguards for road ...
[Closed] Mudguards for road bike with no mounting points
[#4296487]
Finally nearing the end of the most frustrating build ever. When / if it is ever rideable I'll need mudguards as it's going to be my commuter. It's a Van Dessel G&T with no mounting points for guards - no bridges, nothing. So whatever gets mounted is going to have to use zip ties, bungees, glue or magic to hold it in place.
So, what really works?
Posted : 25/08/2012 1:56 pm
I currently have these
http://www.merlincycles.com/bike-shop/accessories/bike-accessories/mudguards/crud-road-racer-mk2-mudguards.html
they are fine when set up but they are an absolute pain as when knocked - when storing the bike they need to be fettled everytie you ride
I had some like these which were much better but broke - clumsy storage so user error
http://www.merlincycles.com/bike-shop/accessories/bike-accessories/mudguards/sks-chromoplastic-mudguards-700c-road.html
You get loads that just attach to the forks and stays but something more rigid than the crud ones would be my choice
Posted : 25/08/2012 2:01 pm
I've seen the seat stay and fork mounted ones used with success in our road club. I actually considered getting some to replace my full gurads as they are easier to take on and off (I use a cross bike and race every other week on it through winter).
Posted : 25/08/2012 2:05 pm
The Crud ones look like they'd work but not the SKS - the forks are disk only carbon ones, so no bolt hole at the top.
Posted : 25/08/2012 2:24 pm
A lot of people use Race Blades ( http://www.wiggle.co.uk/sks-race-blade-xl-clip-on-mudguard-set/?utm_source=google&utm_medium=cpc&utm_campaign=uk&gclid=CKnw0_zvgrICFeTLtAodAA4Agg) but I found them to be a right PITA. As above, one slight knock and they're out of line. Good if you want to take them on and off (my least-favourite bike job is mounting mudguards...) but rubbish as a permanent install.
My advice would be to spend some time in getting / making some brackets from various bits of bent metal to allow you mount normal mudguards onto your frame /forks. For the forks in particular, this wouldn't be difficult.
Posted : 25/08/2012 2:26 pm
Cruds are attached to the front brake on mine so I doubt they will work - they will almost certainly rub if you cannot attach ther e- tbh they will almost certainly rub anyway IME but it is very slight when set up
Posted : 25/08/2012 2:36 pm
Race blades are pretty good - as good as you would get for that sort of easy-on easy-off guard. The front one mounts round the fork leg so would fit any road bike I would think.
Once you've run them so you're sure of the correct orientation, you can screw the guard so it doesn't move relative to the mount - this stops them moving IME.
If you do get something like these make sure you helitape the bike where the mounting will strap on - I put 4 nice corrosion spots onto my pompino from not doing this over last winter.
Posted : 25/08/2012 2:45 pm
I use these jobs.
They are easy to fit/remove, three minutes tops. I just keep them on this oldie now. They work to, rode though a ford Tuesday no problems. And if they get knocked you just slide the rubbers again.
Posted : 25/08/2012 2:51 pm
I've used Raceblades with no issues getting them knocked
Posted : 25/08/2012 4:26 pm
I use raceblades. A good tip is to put a bit of old innertube on the fork where they connect and use tiewraps if you will be.leaving them on for a while. They stay in place very well then.
Posted : 25/08/2012 5:31 pm
Thanks all.
What's good enough for that Oldgit is good enough for this one.
Posted : 26/08/2012 1:26 pm
I've got a set of RaceBlades for my CX bike but I found they rubbed a bit when attached with the standard rubber bands. I'll try zip-ties this winter.
Posted : 26/08/2012 1:31 pm
