Moving from 8 to 10...
[Closed] Moving from 8 to 10 speed
I am planning on upgrading my old Pariot LT from 8 speed to 10 speed on the back. I know I can still use my existing Bulb hub, but do I need a 10 speed specific rear mech? I have a short cage on there at the moment with a Dual crank up front. Any help muchly appreciated.
Posted : 04/11/2013 3:00 pm
 qtip
Yes you do.
Posted : 04/11/2013 3:11 pm
What he said.
Posted : 04/11/2013 3:15 pm
What clubber said
Posted : 04/11/2013 3:22 pm
what ndthornton said
Posted : 04/11/2013 3:23 pm
What muppetWrangler said about what ndthornton said about what clubbed said.
Posted : 04/11/2013 3:28 pm
 ojom
I echo the above comments wholeheartedly. Opinions endorsed as fact.
Posted : 04/11/2013 3:29 pm
Ahhh its so childish ๐Ÿ™‚
On a serious note......
2 gears is a big jump!
Id recommend getting used to 9 speed first before attempting 10.
Posted : 04/11/2013 3:31 pm
Thanks for your comments qtip and clubber, whatever they were.
Should I get a medium or a long cage rear mech then?
Posted : 04/11/2013 3:37 pm
Depends what you're running up front. Long for a triple, medium for a double.
Posted : 04/11/2013 4:05 pm
What he said ๐Ÿ™‚
Though with the caveat that if you don't run a wide range cassette and the chainrings aren't too different on a double then you can use the short cage
Posted : 04/11/2013 4:28 pm
I would be running a normal box standard SLX cassette, whatever that range is.
Posted : 04/11/2013 5:15 pm
That could be 36-11, 34-11 or 32-11. Comes in three different sizes IIRC.
Posted : 04/11/2013 6:25 pm
 JoeG
I went from 8 to 10 speed earlier this year. 10 speed with the clutch derailleur is fantastic!
Posted : 04/11/2013 11:38 pm
What size could I get away with using a medium cage with a 36-11 cassette?
Posted : 05/11/2013 12:43 pm
It's not about the size of the chainrings, but the gap between them.
Others on here will be far more qualified to answer this than me, I tend to just go with what 'feels right' at the time.
Posted : 05/11/2013 7:56 pm
