Has anybody done it? Did it work well, any products that can be recommended?
The only thing I've been able to find isย https://www.sjscycles.co.uk/brakes/problem-solvers-mismatch-12-adapters-shimano-ispec-ii-brakes-to-sram-matchmaker-shifters-pair Anybody tried it?
my Reverb 1x came with a little clamp so you could mount it independently of the brake lever, would that not work or do you want it on the same clamp?
I'm going to try that but i like the idea of the bars being clean as poss.
There's already so much on there.
I am using that ProblemSolvers adapter to mount my SRAM shifter to an M8000 brake lever, should work just fine with the Reverb 1x lever as well.
I have that ProblemSolvers adaptor too - to do that very thing.ย Unfortunately I have I-spec 1 levers at the moment...
