Hi
i have a frame with no lower rack mounting bolt holes - just the upper. i run Vs too, can i just use a disc specific rear rack? Or will it get in the way of the Vs?
ta
Ben
Posted : 12/02/2009 2:12 pm
Can't see any problem with V brakes - the disc specific ones are presumably designed to clear the rotor. You can get 'wrap around' clips that the feet of the rack bolts to.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=18507 ]A bit like these[/url]
Posted : 12/02/2009 2:20 pm
P clips or look at Tubus stuff - they have all sorts of fitting kits
Posted : 12/02/2009 2:23 pm
