Mouldy nozzle!
[Closed] Mouldy nozzle!
9 Users
Does anyone else find that their Camelbak podium nozzles go black and mouldy after a while? I find that I need to dismantle them regularly which I do not think you are supposed to, in order to clean the insides particularly the wee blue rubber disc valve.
Is it just me?
Dogsby
Posted : 26/03/2016 11:09 am
Not a problem I've ever had. What do you put in them?
Posted : 26/03/2016 11:11 am
I sucked a spider into the nozzle last week,it must have crawled into the bladder whilst it was drying in the shed,textbook mistake not to check it I suppose,I can't for the life of me get it out so getting a new nozzle,you can get a cotton bud in there to clean it.
Posted : 26/03/2016 11:17 am
Yes, mine do this too. I just let it build up and then take them apart them every couple of months to clean. Doesn't seem to have done too much harm so far. I guess you could soak them in sterilising solution, might get rid of the mould without requiring the fiddly dismantling process.
Posted : 26/03/2016 11:21 am
I sterilise mine every couple of weeks and I have seen that problem too! You're not alone.
Posted : 26/03/2016 11:46 am
Flush through with milton fluid after use if not using for a while,don't store in warm place too .
Posted : 26/03/2016 12:07 pm
I just rinse with the hottest water i can get out of the tap, then blast it through the nozzle. Loosens everything up enough that a normal hand wash (with the silicon bit removed) gets rid of all the clag.
Posted : 26/03/2016 12:15 pm
Mine gets stored in the freezer. Problem solved.
Posted : 26/03/2016 1:14 pm
I had never thought of the freezer.
Great to hear that it is not just me. I only ever put water in mine and still they end up manky even with the new ones. Clearly more cleaning required!
Dogsby
Posted : 26/03/2016 2:11 pm
There are 2 separate things here. Podium bottles and bladders
I have 7 podiums I think, and a bladder. I do see the problem with podiums, but not very much. The newer ones are much better and the mouthpiece comes off for cleaning. Otherwise the back of a teaspoon works pretty well for cleaning
Posted : 26/03/2016 4:14 pm
