Most reliable 120mm...
[Closed] Most reliable 120mm / 100mm fork
Ok after failing to get a manitou minute second hand, im now considering buying a new fork.
What is the most reliable 120 or 100mm fork. Im not too concerned about anything else.
Any views on the Marz Pro Lo 2009?
Is the Fox Vanilla going to get shredded by UK weather?
Im about to build onto a frame that can take 100mmm to 140mm, this will be my only bike. So reliability and cost is important.
Posted : 17/05/2009 3:36 pm
 jim
Reba?
Posted : 17/05/2009 3:51 pm
reba seconded. ****in brilliant fork, whether you think value, performance, reliability durability. kicks arse on every front.
Love em.
Posted : 17/05/2009 4:19 pm
You should've wanted my Nixon - 145mm with the rear arch makes a short fork (reliability has never been questioned) for little money.
Posted : 17/05/2009 4:22 pm
What frame is it?
Why 100 or 120mm of that range?
Hi,
I'm new here.
Been running a reba fork for two and a half years, around five thousand miles. no problems mostly XC and trail. Had spacer removed & service recently so travel is now 115mm 🙂 extraordinarily good.
Posted : 17/05/2009 4:50 pm
Its a dialled PA.
I say 120/100mm .. because i live in a very flat county..
The idea being with this frame i can take the bike almost anywhere in the UK.. but prob go for shorter travel because stuff here is tame and i sometimes ride on road for fitness (this will be the only bike i have)
Also i maybe moving to london in september..
Hairy have u got it still? My main concern was the axle to crown and riding 145mm sometimes on the flat
Posted : 17/05/2009 5:05 pm
Don't restrict yourself to 100-120mm unnecessarily: the PA works *perfectly* with 130mm forks. Revs work just fine 🙂
Posted : 17/05/2009 5:12 pm
Recon 351's are reliable & much cheapness.Also,lots of adjustability from 85mm/100mm/115mm up to 130mm.
Posted : 17/05/2009 5:17 pm
Been running a fox float R for two years, around five thousand miles. no problems mostly xc trail riding with peaks and lakes too. They are 120mm, not been serviced but lifted seals recently and oil still looked like new. Love em lots more than my revs on my other bike.
Posted : 17/05/2009 5:28 pm
i like my durins, lighter than light, stiff and track lovely and better than the fox f100rlts i had before, by a long way but cant advise on other choices as never ridden em, durins good thou imho
Posted : 17/05/2009 5:34 pm
magura's rock, but they dont have adjustable travel, i'd go for U-turn Rev's, the you can drop it to 100mm for local trails, nd bump it up a bit for weekends away.
Posted : 17/05/2009 6:11 pm
Yes, and the axle-to-crown is only 520mm (with a flexible tape). Interested? Email me if you want privacy 🙂
Posted : 17/05/2009 8:09 pm
Could sell you a pair of minute 2's for £100?
Posted : 17/05/2009 8:14 pm
How about Recon 351 U-Turns, Royles have some brand new ones for £260.
Posted : 17/05/2009 8:29 pm
I love my menjas, but as you say, no adjustable travel. Try to get hold of last year's Laurin?
Posted : 17/05/2009 10:13 pm
