Obviously you need to remove the skewer to take the wheel out
If the wheel is converted to 135x10 (is that possible easily) will that work ok?
Posted : 22/04/2014 10:34 pm
You can only run 142x12 if converted, hub will be 7mm too narrow and need a 12mm axle
Posted : 22/04/2014 10:43 pm
Depends on the wheel. If it can be converted to 135x10, chances are it can also be converted to 142x10.
What hub is it?
Posted : 23/04/2014 7:38 am
ah - its an old XT cup and cone, so doubt it can actually be converted
however, the frame I was looking at takes QR, not 142x12 (older model) so its a moot point anyway
cheers for the reply
Posted : 23/04/2014 10:05 am
