Monstercross Niche ...
[Closed] Monstercross Niche - 26er 'monstercross' bikes
 cp
Inspired by the large 26er slick tyre thread
http://singletrackworld.com/forum/topic/using-26-rims-and-fat-tyre-instead-of-700c-rims-and-roady-tyre-on-a-commuter
I'm pondering re-apportioning an old 26er Inbred frame to boy-nursery run/commuter monstercross bike.
Any pics for inspiration or advice to avoid it like the plague?!
Posted : 29/11/2017 4:47 pm
Having just acquired an old slot dropout inbred frame, which is currently on the turbo with a slick tyre but otherwise standard mtb guise, I’m interested in what I might do with it in the spring so watching this thread...
Posted : 29/11/2017 5:07 pm
I've got a sliding dropout steel Voodoo SS that I've been tempted to drop-bar, but as it would involve buying new brakes as well it's on hold as my remit for it was to use it without spending out on it!
Posted : 29/11/2017 6:57 pm
I've also got a 26 inbred. Once I get round to getting a new hardtail I'm planning to give it a go. I think the geometry works but there's only one way to really find out!
Posted : 29/11/2017 7:01 pm
bindun
Raced this at SS European championships and Central League
[img] ?oh=49ba62736a09bab9076dc609e2ba43ea&oe=5A8EF480[/img]
Look closely and you will see TWO rear cogs, depending on terrain. Fork is for 700c. Weight is 20 lbs. Tyre choice is challenging - basically CX Pros, mine are run tubeless. Bars are Soma Sparrow as I too didn't want to change levers. Works fine.
Posted : 29/11/2017 8:07 pm
 Bez
Is that monstercross or is it just skinny tyres and a sweepy but essentially still flat handlebar? 😉
Posted : 29/11/2017 8:16 pm
It's a 26er with the only 26er cross tyres available and raced in cross races 😛
I couldn't justify a new set of brakes and had the 100 mm 25.4 mm stem already.
Posted : 29/11/2017 8:30 pm
 Bez
Don't get me wrong, I'm not knocking your lifestyle choices 🙂
I just had monstercross down as "drop bars and fat tyres", but I can't keep up with the bandwagons. If it's a bike it's all good*.
* apart from the bad ones, obvs
Posted : 29/11/2017 8:38 pm
Proper gravel bike you mean, not a CX bike with a holdall slung under the top tube to carry a picnic
Posted : 29/11/2017 8:42 pm
I was thinking drops and 26x2.0 xc tyres
Posted : 29/11/2017 9:07 pm
I could always put the old tyres back on 😉 . Won't get me near the top 10 though! Drops are fine too. My "real" cross bike has those - but I actually prefer these off road. I built this before the term as coined. Mud clearance is enormous, as was enviously noted after it's first Hillingdon outing - killer of RDs par excellence, by a couple of riders pushing their bikes - one after his practice lap 😳 .
Posted : 29/11/2017 9:28 pm
 cp
Interesting thoughts folks. I think an issue I'm going to have is that the head tube is short and the steerer shortish.. along with the fork only being 420mm AC, I think I'm going to have trouble with the bar height being too low. I might just give it a try though 🙂
Posted : 29/11/2017 9:47 pm
cp - Member
That's precisely why I ended up using a 45* stem on my brief experiment. Went back to a flat bar and barends in the end as I just couldn't get the position right (too low and long on an old Kona).
A steerer extender and something like this would have been better, but I couldn't be arsed:
[img] https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQX6B4wUAweZzlJpXxxbYiYlqnKopZ-gVdcNqGSgrqP4109TCeClQ [/img]
Posted : 30/11/2017 9:43 am
A part of me wants to buy 58cm https://www.planetx.co.uk/i/q/HBNIRM3/nitto-rm-3-gravel-handlebar for the Wazoo, if I could simply clamp the gear shifters and brake levers on the central flat section. 😈
Posted : 30/11/2017 11:25 am
