I have an old steel Kona Cindercone frame and some nice late forks, I am going to build up a bulletproof Bikepacker from the parts bin, all seems in order except for the brakes.
The frame is v-brake only but the forks are disc, if I use the discs up front and the v-brakes on the back will I die?
Only if you use a non disc wheel on the front and disc only wheel at the rear. 🙄
Wow! never thought of that, thanks. 😯
Was more interested in the physics of braking, cars have mixed disc/drum and the effect is understood, is this similar on a bike?
You'll be fine. Front brake for stopping really.
APF
A V-brake on the rim is just another disc really...with a bigger rotor and a smaller pad/caliper
It's not a drum and therefore the physics would be similar to the front brake
I ran a magura HS33 on the back with a deore disc on the front and it was great for commuting. Never got the chance to run it off-road tho cos someone stripped the frame before I got the chance
It'll be fine, I ran a BB7 up front and DX V's on he back of my old Trailstar.
My singlespeed has got v-brakes on front and caliper on rear. I haven't died yet so you are even less likely to die with discs on front.
Just do it!
Isn't the effect just like having a smaller rotor on the back, thus meaning it will be fine?
I used to run a V on the front and canti on the rear of my old Kona.
My Solitude used to be disk-front and V-rear, but is now disk-front and fixed-rear.
I ain't dead.
We all used to do it BITD! Was 2006 before I had a bike with F&R discs!
I rememember when all this were fields.....
Or 4-pot on front, 2 pot on rear - which I do as well on another bike
Thanks chaps, confirmed my thoughts but thought it better to check - clearly will need an appropriate rim for the back but that's another step closer to a bikepacking trip. 😀
