Is it Hope calipers that have an interference problem with Shimano discs, or vice versa?
Posted : 19/12/2016 5:22 pm
From experience I've found that:
1. The pad of an E4 is deeper than the braking surface of a Shimano RT76 rotor. No interference problem as such, but not getting full efficiency from pad. Swapped to a Hope rotor.
2. The rivets of a Hope 203mm floating rotor do catch on the post-mount slot of an M785 XT calliper. I suspect this is the situation you're worried about.
Posted : 19/12/2016 5:38 pm
Thank you!
Posted : 19/12/2016 6:02 pm
