Mismatch adapters -...
[Closed] Mismatch adapters - available in the UK?
Has anyone ever seen something like this available in the UK?
http://problemsolversbike.com/products/mismatch_adapters
I'd like to use an i-spec shift with Avid brakes, so this would be perfect
Posted : 18/02/2014 10:31 am
Bump for the evening lot. Although I'm 99% certain I know the answer
Posted : 18/02/2014 8:45 pm
Ison distribution?
Posted : 18/02/2014 8:58 pm
Ison don't have any and there's no ETA for when they will.A phone call to them will be required.
Posted : 18/02/2014 9:01 pm
Ah well, if they don't have them I'll be bigger then. Interestingly, they only list the I-spec shifter to Avod brake one instead of the one I need
Posted : 18/02/2014 9:17 pm
Does the avid brake clamp match up with the hope tech brake clamp. If so, you can use a hope matchmaker. This is what I am doing with my formula rx brakes and my slx I-spec b rear shifter.
Posted : 18/02/2014 9:31 pm
I've gone for some KCNC adapters in the end, slightly more than 1 shimano cal + clamp but far better value than a pair. The only problem is that they (well the 1 i'll use) look like a right pain to fit to the shifter, time will tell.
Posted : 20/02/2014 3:41 pm
Yes, triton cycles. (Triton cycles.co.uk). I got a set to put xx1 shifter on to XTR levers, but they do other way also. Not cheap though, for a tiny piece of alloy.
Posted : 20/02/2014 3:46 pm
Wrong way round for me (and not in stock till the end of April), and bloomin' eck they make the KCNC ones look even better value!
Posted : 20/02/2014 4:23 pm
for anyone interested, i now know the difference between i-spec A and B - B wont fit in the KCNC clamps ๐Ÿ™„ Should only take 2mins with a file to sort, just an extra pain though
Posted : 01/03/2014 12:05 pm
