Milkit tubeless val...
[Closed] Milkit tubeless valves issues with air pressure?
Just got some milkit tubeless valves... Great idea to stop clogging
Issue I'm having is when taking off the pump head... A lot of air escaping before I get chance to screw down the presta head
Now if I pull the presta head up as soon as I disconnect the pump head it closes the valve inside the tyre... But I'm still loosing a fair bit of air even as I do that?
Am I missing something? I'm use to just pulling off my pump from the valve and no air escaping so I can use my pressure gauge to see the psi I'm running... But when I attach the pressure gauge the same thing happens upon release so I lose another couple of psi
Any ideas what I'm doing wrong or is this just how it is?
Posted : 16/10/2018 10:56 pm
Strange.  I have two sets and haven't had this
Posted : 16/10/2018 11:16 pm
Yep, I have the same issue.
Liked the idea when I bought them but with this and the added agro of adding fluid (I normally add through the valve) I kinda feel for me they’re an answer to some problem I never had. Nice quality valves though.
Posted : 16/10/2018 11:40 pm
Mine work great, pump up as normal and I don't get any air escape. Big advantage is being able to check sealant levels and top up if necessary without popping off a bead and risking lifting the edge of my tape. I only tend to change tyres a couple of times a year though
Posted : 16/10/2018 11:47 pm
Splodge phewwww thought I was being stupidly dim but glad to hear its not just me
I haven't bought the sealant syringe thing literally just the valves
They do pump up better no doubt and it's a better flow of air combined with the fact they don't clog
But the air escaping makes it really really hard for me to get a accurate psi reading
Rubber struggling see how you don't have any air escape as soon as I pull the pump head off its gushing it out... So if I put my gauge on release it I lose another 2 psi or similar meaning my digital gauge now becomes pointless
Unless of course we are both being dim and missing something ha
Posted : 16/10/2018 11:52 pm
bump for morning crowd, anyone else found this?
Posted : 17/10/2018 11:10 am
I had this on my one of mine. I hadn't installed it correctly and the tube in the valve had pushed through to rubber end part and left it open. So when I unscrewed the valve loads of air came out.
It still wasn't that much of a hassle, as I could still put new fluid in, I just had to let the air go to almost nothing in the tyre.
The bigger problem I'm having is getting the valve to have a good seal on the rim I have. It works, but it relies on it being sealed with sealant and this breaks if I try to top up with air via a hand pump. Not solved this yet, but I'm hoping a strip down, clean up and re-install will solve it.
Posted : 17/10/2018 12:04 pm
Actually, I think I've miss-understood your original query. I was meaning if I unscrewed the valve, I've never had problem with just using the presta valve 'normally', other than the "vigorous" hand pumping breaking the valve seal as described.
Posted : 17/10/2018 12:07 pm
It sounds like yours are sticking open when they should close by themselves.  If I want to let some air out I push the valve in like I would any other presta valve then when I let go the valve seals and no more air escapes.  Sounds like you'd have to pull yours closed so I can only guess they are faulty, I can't see that you are doing anything different to what I do.
Only issue I've had was trying to remove sealant with the tyre at 20psi.  I forgot to close the butterfly valve on the syringe and got sprayed with sealant 🙁
If you don't have the syringe you are missing out on the main benefit of the valves.....and they aren't cheap are they.
Posted : 17/10/2018 12:13 pm
yep sounds like a different issue traildog
mines is purely just getting the pump head off or a digital gauge head off with losing loads of pressure
everything else seems spot on so far
