Middleburn RS8- can...
[Closed] Middleburn RS8- can the axle be swapped?
I've never had these. Is it possible to convert a standard set to fit a fatbike? I'm assuming the axle is bonded/permanently fixed to the NDS.
Posted : 19/11/2014 10:17 pm
you can buy them with a longer axle but I'm pretty sure it's fixed
Posted : 19/11/2014 10:23 pm
That's what I assume, I was just hoping someone was sure.
Posted : 19/11/2014 10:50 pm
I'll have a look in the morning if you want, but
[url= http://www.middleburn.co.uk/x-type-fitting-instructions.pdf ]The Left crank arm and bottom bracket spindle are assembled in our factory as one unit and is designed not to be disassembled[/url]
Posted : 19/11/2014 10:53 pm
Well, you're not meant To be able to completely remove the axle. However, it is possible as I've done it on my old ones. Will need a bit of effort and a breaker bar on the end of the hex key but yes, can be done.
why did you do it flange - can you buy replacements ?
Posted : 19/11/2014 10:57 pm
Anyone else tried this?
Posted : 20/11/2014 4:03 pm
 eep
Middleburn will swap the axle, its mentioned in the thread here: http://singletrackworld.com/forum/topic/middleburn-rs8-x-type-2
Posted : 20/11/2014 4:27 pm
