Mid 90's Kona ...
[Closed] Mid 90's Kona - ok with 80 or 85mm travel forks?
 benz
If yes, what would you recommend?
Anyone got any decent ones with 1.1/8" steerer about 220mm long?
Posted : 08/11/2010 9:52 am
i have a mid nineties kona with 100mm fox floats, and that's fine. does that help?
Posted : 08/11/2010 10:03 am
I have a 1993 Marin frame fitted with 100mm Marzocchi forks and it is fine. If anything the handling is improved as it is less twitchy.
Posted : 08/11/2010 10:06 am
I had a '96 Kona Lava Dome with 100mm Marz. forks back in the day. It was fine, but I swapped for 80mm forks later and felt that that was better.
Posted : 08/11/2010 10:31 am
IIRC the mid 90's explosif came with 100mm bombers?
Posted : 08/11/2010 11:10 am
i've got a '96 hei hei with f80s and its doing fine
Posted : 08/11/2010 11:40 am
'99 Kona Nunu with rock shox jett 100mm forks (till i changed it to rigid)..........was fine.
Posted : 08/11/2010 11:43 am
sorry, it was the '97 king kahuna that came with bombers.
Posted : 08/11/2010 12:14 pm
you wouldn't happen to be selling the project 2's at all would you?
Posted : 22/11/2010 1:53 pm
My '95 Kilauea is acceptable at 100mm though maybe a touch slower than ideal but you get used to it. It does depend on the fork though - I use Pace specifically because they're short for the length of travel.
Posted : 22/11/2010 1:55 pm
I found my '98 explosif too barge-like with 100mm forks. I only run 80mm or rigid now. The whole point of it to me is that it feels snappy and quick.
Posted : 22/11/2010 2:39 pm
I had a '99 Pahhaoahaoehhaohehaoheoahe which was designed around 65mm forks, and I had 85 and 105 (and a rigid) over time, and 85mm felt the best for single track riding.
Posted : 22/11/2010 5:26 pm
 OCB
My 92 Fire Mountain had 100mm Manitou's for a bit and it felt great.
It's now got rigid PII's on, but the 29er versions at ~465mm, and it feels like a barge. ๐Ÿ˜›
(It's like riding my old GS1000 again).
Posted : 22/11/2010 8:37 pm
