Mechanical disc bra...
[Closed] Mechanical disc brakes, yes or no?
Yonks ago I had a Kona Dew with cable discs (2004?), which stopped so badly it was in the shed more than on the road. Terrifying. I'm currently musing on a cyclocross bike, but modern low end (i.e. affordable by me) ones all seem to have these mechanical ones, and I'm extremely loath to risk it.
Was my original bike just a bit duff? Has technology moved on enough in the intervening decade to be confident of such brakes these days?
Andrew
Posted : 26/08/2016 8:33 am
They're still a bit hit and miss, but I've never had a terrifyingly bad set. Any bikes in particular you're looking at? What brakes do they have?
Posted : 26/08/2016 8:39 am
2nd hand hydro brakes aren't expensive.
Posted : 26/08/2016 8:42 am
Avid BB7's seem to get good reviews
Posted : 26/08/2016 8:43 am
Technology has certainly moved on but in my opinion cable disc brakes are simply just not great. Loads of people run them and are happy but for me I'd only buy hydraulic. Main reason being lever feel, with hydraulic you can 1 finger brake and needs little force. With cable you often need a hand full and great force, plus cable/system stretch which often means long lever travel and even going to the bars before you lock a wheel. And then you have the single sided pad actuation with most of the cable disc brakes, another weakness and pain to take care.
So for me no.
I've just taken off a pair of FSA CX Expert calipers and gone Shimano hydraulic, the difference is another world, in all ways. The negative is that buying hydraulic cost more, but for me it’s definitely worth it.
Posted : 26/08/2016 8:46 am
Cable are nowhere near as good as hydro. I have cable on my Saracen road bike and don't really like them, but I only paid £400 for it new so beggars etc....
Posted : 26/08/2016 9:04 am
Mrs Dubleyou has them on her x-bike, but came from a pretty crappy BSO so hasn't complained.
IIRC, they are BB7s.
I wouldn't trust stopping my mass to cable disks.
Posted : 26/08/2016 9:07 am
I run Shimano, Hope and Avid BB7s on different bikes. All slightly different feel, but when well set up they all work equally well.
A lot of issues people have with mech discs are (imo anyway) down to setup. They take a while to dial in, but once done they just work until it's time to change pads.
Posted : 26/08/2016 9:28 am
 Del
[url= http://singletrackworld.com/forum/topic/cable-disc-brakes-bb7-any-good ]here[/url]
[url= http://singletrackworld.com/forum/topic/mechanical-vs-hydraulic-discs-advise-for-mtbiker-stuck-in-time-warp-please ]and here[/url]
anyone who reckons you need a full hand to get cable brakes to work, or just thinks that they're crap across the board, just hasn't used a set that have been set up properly.
all you're doing is altering the method of transferring the force applied by your finger to the caliper. if the losses involved were that significant then cables would be rather useless for changing gear with, wouldn't they?
Posted : 26/08/2016 9:38 am
Thanks all for your input. Sounds like my fears might be well-founded.
@jimdubleyou, good point re mass. At 90kg I should probably bear this in mind...
@ajantom, set-up is one of the reasons why my old bike was off the road so much. Must have gone back to LBS thrice to be looked at.
Should I assume though that cantilevers are mostly going to be better than cable discs?
Posted : 26/08/2016 9:39 am
Interesting, usually these threads are mostly pro-cable disc with a few legitimate or otherwise detractors.
I've had two sets of Avid BB7s, which both performed great with not too much attention (i.e. I didn't do anything fancy with outers, but did follow Avid's instructions re: calliper set up). Lever feel is perhaps marginally 'rougher' than hydros but still plenty of power and one finger breaking.
I noticed pad wear more on long wet descents, once or twice I had to adjust at the bottom but that could have been down to newish pads that hadn't bedded in. For a CX bike I wouldn't be as concerned unless you plan to ride it like an MTB down long, muddy, brake-y descents.
Like the look of the TRPs, if only because you can use Shimano pads with them and Shimano metal pads are my favourite pads for long life and not too much noise in the wet.
Cheap cable discs are the work of the devil though, Would only go Shimano CX77, Avid BB7 or BB5 if I could be bothered with the tinkering, or TRP.
Posted : 26/08/2016 9:41 am
@Bream - some mech disk brakes now have dual pistons - the TRP Spykes for instance. Unlike hydro systems they aren't self-adjusting so you do need to keep an eye on that side of things. I've the Spyres on my CX and they work more than well enough.
Does depend on what sort of riding you do of course: DH and Alpine trails then definitely hydro; pootling round Centre Parks or similar then mech disks are more than adequate.
Posted : 26/08/2016 9:42 am
I've got BB5 and BB7 on my CX.
They are ok, not as powerful as hyrdos, and need readjustment every so often.
If a bike comes with them, not the end of the world, but I personally wont be buying them again, next bike will be hydro. Better performance, less faffing.
Posted : 26/08/2016 9:45 am
Definitely not! Discs will be much better than cantis, especially if it's wet or muddy.
I was talking about initial setup - take a bit of time getting the pad distances and angles set up, and all you then ever have to do is turn the red dial to make up for pad wear.
I'm 90kg or so with kit, and have BB7s on a Surly Krampus. They stop me plenty good enough!
Posted : 26/08/2016 9:46 am
I wouldn't assume this, my experience of road cantis is that they are rubbish compared to cable disks or v brakes, this is Tiagra level cantis though.
What I have gleaned is that disk brakes work just fine as long as they are not crap disk brakes and they are set up with suitable brake cable outers.
More massive people need more massive brake disks. Disk size is more important than cable/hydro AFAIK.
Posted : 26/08/2016 9:47 am
Cable disks can be fine, and can be the equal to hydros, the problem is that crap cable brakes are crap, not because they are cable, but because they are cheap crap.
A basic cheap hydro will 99% of the time be better than a cheap cable disc, but decent cable discs like BB7s and Spyres, and some of the posher Shimano options, set up properly with decent cables can easily rival a decent hydro*.
There's plenty of people on here who either run both hydro and cable on different bikes, and some that have even swapped FROM hydro to cable and are happier for it.
There's also more to a brake than just it's immediate power. Power, serviceability, reliability, ease of adjustment, robustness, heat capacity and how it deals with it, failure modes, on trail fixability, potential for contamination etc. Some of those other aspects mean more to some people than others so horses for courses and all that.
In summary, decent cable brakes will be fine if you set them up and look after them (same as hydro really...) but if you don't get on with them then there's cheap Hydros available to swap to.
^ think about those comments for a moment, cos they come up a lot, not to mention that I have configured BB7s before that were too fierce (and broke a disc mount off a fork), it's not about the intrinsic system type, it's about the specific system.
Hell, back in the mid 00's I was using BB7s on my trials bike, because they were better and more consistent than the Hope and Hayes options at the time, and more robust. The one thing you don't want on a trials bike is a brake that lacks power or can't be modulated properly!
The amount of force your finger can apply is the same regardless, it's your finger after all.
(Assuming equal disc size) The amount of that force that gets exerted on the disc and how well it stops you are governed by three things:
1 > leverage/piston ratio between lever and calliper
2 > the performance of the brake pad/disc interface
3 > losses in the system
Point 1 is mostly null as you can alter piston sizes and lever ratios and actuation arm sizes etc. so you can achieve the exact same result from hydro or mechanical so one isn't automatically better.
Point 2 can be nullified too as you can use the same pad compounds in either system, however cheap brakes often come with cheap pads too, compounding the perceived difference in system types.
Point 3 is the issue, not at the lever as cable and hydro levers can be built equally stiff, pretty much the same with callipers except for the tiny losses in flex in a cable actuation arm and friction in actuation mechanism, but these are tiny.
This leaves the cable... even the crappiest hyraulic lines do a damn good job of getting the force from one end to the other with minimal losses, cables can be much more variable. A decent cable, installed correctly, with compressionless outer, nice squarely cut and filed ends with good interfacing surfaces does this job pretty damn well too, an that's the key.
Cheap flexy outer, badly cut ends, dodgy interface surfaces/angles and poor setup are what kill the performance of cable discs. And most manufacturers, especially at the cheap end don't commit the necessary time and money to getting that bit right.
Posted : 26/08/2016 9:49 am
 ton
long term user of avid bb7 here. anyone who say's they are not as good as hydro's has A. never used them, or B. never set them up correctly.
got them on both of my bikes at present, and as a 20 stone rider, i kind of know if a brake is good or not.
Posted : 26/08/2016 9:56 am
 Del
balls. fitted BB7s to my 5 specifically to take to the alps, lift assisted and uplifted.
i don't 'do DH', so wouldn't comment on that application specifically, though i have ridden DH trails in wales, and also the french, italian, and swiss alps, and muddled through OK.
common wisdom has it that cable disk brakes aren't any good though, and the majority are always correct, right? 😀
Poor cantis are useless.
Poor cable discs are useless.
Poor hydros are barely functional.
Good cantis, well set up, on decent rims, with decent pads/cables etc will be as good as average cable discs. But can be variable.
Good cables discs, well set up and looked after with good compressionless cable outers are as good as average hydros.
Posted : 26/08/2016 9:57 am
 kilo
I have used cable (Haynes)cable / hydro combined (juin tech) and sram hydro. I found the cable to involve much more faffage than the others. Cable hydraulic combo were good and pretty fit and forget and provided better stopping, they are still on my spare cx bike. The sram have been completely fit and forget and the best working. I ride my cx er on longish runs rather than race and do reasonably technical descents on it
Posted : 26/08/2016 10:01 am
BB7's are decent but hydro's are better. I used to use BB7's on most of my bikes but all of them have hydro's now.
Posted : 26/08/2016 10:03 am
Just looking on CRC and the TRP Spyke is £80 per end for caliper only, the BB7 is £75 per end again caliper only whereas the XT is £70 per end for caliper, hose and lever. On that basis I'd go for the XTs.
Posted : 26/08/2016 10:06 am
And yet there are people who (if they see this thread) will pop on here and claim the exact opposite.
FWIW, I'm one of those people that has cable on some bikes, hydro on others, and somehow I still mange to not die when swapping between them.
forums eh, can't trust em 😉
BB7 work just fine, want to buy my bike in the for sale section?
Posted : 26/08/2016 10:12 am
I have BB7's on my PlanetX XLS and they have been faultless. Plenty of modulation and with 160mm discs I'm still able to lock up front or rear if I want and over 90kg of Ajoten. Yes they need a bit on manual adjust to compensate for pad wear that you wouldn't need to do with Hydraulics but it's no deal breaker as it's very simple to do.
The limit of the BB7's isn't in the brakes themselves but the available grip of the tyres.
Posted : 26/08/2016 10:14 am
 ton
the power of a bb7 used with 200mm disc is far superior to any hydro set up i have ever used, including shimano saints.
if i ever went back to hydro's it would be saints that i would buy.
 kcr
I used BB7s for about 9 years of commuting. They were much better than rim brakes, but more fiddly than hydro to get setup correctly. For me, their big failing was that they didn't stand up to winter conditions, and quickly corroded and started sticking.
I am now using TRP HyRds, which are a big improvement. Better feel, better braking and self adjusting. I will upgrade to full hydro eventually, but expect to be running on 9 speed for a few more years.
Posted : 26/08/2016 10:17 am
Ok, so what I'm getting from this thread is that I'm a brake snob and shouldn't rule out a bike with cable disks (esp. BB7s) as long as I learn to set them up properly.
whitestone - Member
The brakes are for a CX bike so the XT's won't really work with drops and BB7's are less than £45 each end which makes them a bargain for performance/£.
Posted : 26/08/2016 10:18 am
BB7 Road are £45 a pair on ebay (with adaptor and bolts, without discs)
Posted : 26/08/2016 10:22 am
@craigxxl - I have BB7s on my On-One Pompetamine, generally they're fine. Two "problems": 1. I found that winter grit/salt meant they need a complete strip down and clean each spring (a spring clean?). 2. The Pompetamine has an Alfine hub so chain wear meant that I needed to adjust the position of the rear caliper on a fairly regular basis, about once a month. This is only a problem for hub gears or single speed setups though.
I certainly wouldn't avoid a bike because it had cable brakes (2 out of 3 of my disk brake bikes are cable) - I've got a Singular Puffin rolling chassis heading my way and I'm undecided on whether to fit cable (TRp Spykes) vs hydro brakes (Shimano SLX) as it's mainly for winter use and, true to interweb forum law, opinion is divided on which is better.
Posted : 26/08/2016 10:40 am
Moving the caliper so the pads are in contact with the disc would be the same regardless of cable or hydraulic so not really an issue as you are still undoing the same 2 bolts moving the caliper back and re-tightening.
Never had a problem with winter salt and grit but I do tend to give my bikes regular cleaning and maintenance so may have prevented the issue occuring
Posted : 26/08/2016 12:01 pm
The TRP Spyres on my bike rusted up in a couple of months of [u]summer[/u] riding 🙁
They needed to be dismantled and (carefully) greased, following a guide that someone posted on here, as the manufacturer considers them non-serviceable (and obviously for dry use only, as there was no grease in the mechanism). The pad adjusters rely on a bit of thread-lock not to back off...
They work just about OK, but I would avoid in the future.
Switching to hydraulics is expensive, both because of the high cost of hydraulic levers for drop bars, and the need to match derailleurs, etc. to them.
If you want hydraulics, buy a bike with them on (IMHO).
Posted : 26/08/2016 12:29 pm
My Spyres have been fine in nearly a year (once set of replacement pads so far) with same use and care as with the BB7s. Know what you mean about the adjusters backing off, reading around it seems to be a common problem. American outdoor kit and dry use seems to be a common theme - you'd think they lived somewhere sunny 😆
@craigxxl I wasn't meaning that the "problem" was with the brakes themselves just that without a tensioner of some sort you'd be adjusting the brake position on a regular basis whichever disk system you used. Obviously with a derailleur you get the tensioner for free with the jockey arm.
Posted : 26/08/2016 1:04 pm
There has been little mention of the biggest issue for me; cable brakes can't adjust as you go. I've had to crash land half way down a descent with levers back to the bars because of no pad wear take-up, and two minutes later been off again to Talybont with full brakes after winding the pads in manually. I have both cable and hydro on different bikes and I'd advise hydro if you can.
I'm with Amedias, Ton etc on this; I have a pair of BB7s on our tandem, with 200mm rotors on both ends. When touring fully loaded with a trailer, we probably weigh just over 400lbs and I've never had a problem braking single finger, front only on fast fun descents. We don't hang about; the tandem has frequently exceeded 75km/h and sometimes well over 80km/h. I've also got one on the front of my 29er commuting bike, which has also been faultless. There's no shortage of control for trickling through commuting traffic or when off-road and feeling for traction. Follow the instructions carefully and they're absolutely grand, plus they will last a whole lot longer than any Shimano hydro up to XT level. At least they don't wee fluid onto my discs....
Posted : 26/08/2016 1:56 pm
I have TRP Spyres on my gravel/cx/whatever bike. They are fine but need careful setup, if you adjust for pad wear with the cable barrel adjusters they feel poo.
Posted : 26/08/2016 2:16 pm
Anecdotes like that don't hold much water with me.
For that ^ to happen the pads must have been worn significantly before you started the descent, with the commensurate affect on lever travel self evident. ie: you should have adjusted them sooner. I don't believe a single descent could wear enough material off the pads in one run to go from 'normal' to levers hitting bar, and if they could then surely the they'd you'd wear the pad to the backing plate on the next descent.
I can believe that they can go from 'noticeably worn and in need of adjustment' to hitting the bar, btu that's not the same thing and if you decided not to deal with it in advance then on your head be it. All rim brakes have the same requirement and nobody bleats on about that.
On my commuter/gravel bike/tourer thing with BB7's I've been through one set of front pads in ~3000 miles, rears are half worn. I have to put a click or two on the pad adjuster every 3-4 weeks, hardly a chore.
Offroad they wear a little quicker, but I check my brakes before I ride regardless of hydro or cable (don't you?) I can count on one hand the times I've started a ride that then required me to then further adjust the pads mid ride, and they were all in the depths of winter in grinding paste, and even then we're talking 1, maybe 2 clicks of adjustment when I stopped for a breather anyway.
IMO the 'they need constant adjustment' argument is massively overstated or again, a result of poor initial setup.
yeah, you shouldn't really as it alters the position of the actuation arm which affects travel and leverage. That's why the wheel on BB7s is so good.
Posted : 26/08/2016 2:20 pm
Hmm, I dunno, I'm largely all forcable discs, including the two sets of BB7s I've had in the past, but I did do one descent which went from my normal lever set up (admittedly slightly closer to the bar than average, but not massively so) to levers virtually at the bar. This was in the Pentlands which are not famed for massive brake burners, but can get wet and gritty. There were probably lots of other factors at play though, could well have been organic pads that weren't bedded in etc.
Point being, it put me off them for MTB use, but not road/CX use.
Posted : 26/08/2016 2:34 pm
organic pads
ah, well that might be related, gritty conditions can burn through organic pads very VERY quickly.
Sintered all the way when offroad for me, especially on cables as you can't boil any fluid 😉
Posted : 26/08/2016 2:53 pm
i've got bb5's on my commuter.
Performance wise, they're great. I can stop good and hard down steep roads with only a firm 1 finger squeeze. They 'feel' a bit crap*, but that's because I haven't changed the cables in about 3 years. i change the pads every year, because i can pick them up both ends for about £12 - they don't even seem to need much adjustment, just a quick tweak every few weeks - i oil the chain and check the tyre pressure more often than i adjust for pad wear.
mechanical discs are fine, really.
(*and i only really notice that when i get on a bike with 'nice' brakes)
Posted : 26/08/2016 3:12 pm
I have Spyres on my CX commuter and Shimano hydros on my gravel bike. Happy with both, but I drew from the STW collective knowledge when setting them up (like only using compressionless outers with mechanical, or using mtb hoses with Shimano hydros).
The Spyres get used daily, I have yet to find them a fault (occasionally adjusting for pad wear is hardly a problem).
Posted : 26/08/2016 3:31 pm
Using heavy duty outers that do not compress improves cable discs . When I first got a bike with cable discs I thought they were a bit pants. After a bit of time setting them up love them and prefer them on my cx/road bikes to hydraulic ones.
Posted : 26/08/2016 3:34 pm
 arel
I use both, and Amedias is spot on. BB7s are reliable, and brake my fat arse just fine. Both have their own advantages, but nothing incredibly significant Hydraulics have slightly more modulation. Cable is more tweakable in the field, and if you're going somewhere remote, you can take a spare cable with you. Bit harder to pack a full oil service kite.
Posted : 27/08/2016 9:00 am
well they are better than rim brakes and suspect that most people using BB7's are running STI's rather than a flat bar set up and up until not that long ago (i'm old) hydraulic wasn't a drop bar option
recently fitted some cheap as chips clarkes' hydraulics on my shopper/gym junker and they feel a lot better than the BB7's i took off my CX stylee which are sat in the spares box - power isn't everything - I can lock up a rim brake or a BB7 pretty easily - modulation rules so hydraulic wins?
Posted : 27/08/2016 11:01 am
I have trp spyres on my diverge and they do work but they take 10x the power though the levers to stop me (I do weight 16 stone) compared to hydraulics.
Apart from price and maybe if you are doing some middle of nowhere touring cable discs are just hugely inferior to hydraulics, I want to slow down without feeling like I'm going to bend the bars...
Posted : 27/08/2016 1:08 pm
The biggest improvement I've heard of for cable discs is segmented aluminum outer and a proper shimano stainless inner.
It was going to be the next stage for one of my bikes about 5 years ago. But a elixir warranty took so long that i bought some slx instead. And the warranty pair came back with xt stamped all over them. 😉
Posted : 27/08/2016 1:24 pm
I think i now have 2 or 3 sets of bb5 and 7 in a box in the attic.
Posted : 27/08/2016 1:25 pm
Got bb7's on my cx. They're fab and way better than cantis. I swapped out the Magura MT2's on my ss/rigid/adventure/gravel/bikepacking/touring machine for bb7's (mtn version) and have run them with both flat bar levers and v-brake compatible sti levers. Always reliable and better than low quality hydros. Much easier to fix at a campsite.
I won't however be swapping my slx or deore hydros from my proper mtb bikes. I just get the impression with the hydros that there is more power on tap and they're less prone to gunk in the gubbins.
Posted : 27/08/2016 3:07 pm
I've used Hayes, Juicy 3's, Juicy Carbons and Tektro something hydraulics. I now use BB7's.
The hydraulics were great but brake-fade on long descents was an occasional issue - could be pads, could be fluid.
I've not had brake fade with the BB7's (touch wood) but that could be because I don't ride down steep hills any more. 😀
With all hydraulics. but consistently with Avids there was always the eventual "lever to the bar moment" when they failed - bleeding by LBS or myself was only a temporary solution.
As we frequently inverted the bikes to remove both wheels (to get the bikes in the car), we found that hydraulics (specifically Avids) didn't like this and would require "pumping up" or in some cases bleeding - not an issue with the BB7's.
In my view BB7's aren't [i]quite [/i]as good as a set of working hydros but are fine. The tips for BB7's I've gathered are:
- Follow the setup guide closely.
- Use Avid Speed Dial 7 levers - they seem better than "normal" levers.
- Don't blame the brakes if you're using after-market pads/rotors.
- Pads and rotors need time to bed in.
- Not everything that comes off Ebay is genuine.
The downsides to the BB7's have been:
- After rough & rocky hooligan rides they often need adjustment - not just pads, sometimes the caliper needs aligning. I think this might be a general issue with the Avid caliper locating hardware as occasionally the hydro brakes did to.
- The cables really need to be replaced regularly.
- For uninterrupted, fully enclosed cable runs to the rear caliper, they can become sticky - I solved this with a Middleburn cable oiler (hardtail) but as Middleburn have gone TU, alternatives may be needed.
Posted : 27/08/2016 3:08 pm
I run BB7s with speed dial levers on my Hemlock using 203/180mm rotors. Bike is 30lbs, I'm 12.5 stone and ride up to T3+. Never felt the need for anything else.
Can set up a pair in ten minutes, and pad adjustment is a one minute job.
Posted : 27/08/2016 6:20 pm
ton - Member
Agree. They are good brakes. Just don't cheapskate on the bits that aren't BB7 (ie cables and levers) and don't let numpties set them up. If good hydraulic brakes came as a set of components we'd hear the same sort of complaints.
They are getting long in the tooth though. I've been trialling Spyres with the double action for a year and that's what I'll use from now on.
Posted : 27/08/2016 6:49 pm
I would consider cables again after my Shimano Hydraulic fiasco.
Just sent my 2nd RS785 caliper back after leaking!
Right at the start of cross season.
Funnily enough the rear brake feels superb!
Any more issues I am thinking of a Hope v-twin or maybe the TRP part cable part hydraulic caliper?
Thanks,
Max
Posted : 27/08/2016 7:07 pm
I *think* the levers on the Diverge (Tiagra 4700?) have a 'variable pull ratio', so they have very little leverage in the first part of their travel. Mine seemed to work better when set up with a lot of slack in the cable (as opposed to the normal advice to 'preload' the arm on the caliper when fitting the cable), but they're still not as good / confidence inspiring as Shimano MTB hydraulics.
Posted : 27/08/2016 11:54 pm
I reckon most road bike levers are far too flexy for disk brakes - you lose too much effort in flexing the lever.
That's why I went to great lengths to track down a dropbar which takes mtb levers.
Posted : 28/08/2016 12:34 am
I'm getting the impression that cable discs are fine but only if you get superior after-market ones rather than the ones the bike came with.
Posted : 28/08/2016 2:02 am
[quote="epicyclo"]I reckon most road bike levers are far too flexy for disk brakes - you lose too much effort in flexing the lever.What sort of crappy levers are you using? And how many holes have you drilled in them?
Posted : 28/08/2016 6:32 am
Got one (BB7) on the front of my single speed which has always been capable of sending you over the bars for greedy lever grabs. More impressively, it is still on its original pads of 12 years ago.
Wifes bike has cable Avids too as they work with the combined levers she likes and are more predictable than hydros.
Lighter feel at the lever is all hydros really have going for them.
Posted : 28/08/2016 8:32 am
The only real issue I had with BB7's is they'd need a bit of cleaning and maintenance if using them regularly in wet/muddy conditions. By comparison the Shimano hydro's I have on most of my bikes now seem almost completely maintenance free in comparison.
Posted : 28/08/2016 9:26 am
My Genesis came with TRP Spyres which *are* the superior after-market ones. They are at least as good as the BB7s on the bike it replaced and with being dual piston setup is a lot simpler.
Posted : 28/08/2016 9:38 am
Spyres are great until grit and grime get into the bearing mechanism.
Then the arm starts sticking and brake lever feel is very heavy.
Two years on my cross bike was what it took to stop them working.
Probably not so much an issue on a road bike.
Thanks,
Max
Posted : 28/08/2016 11:37 am
ghostlymachine - Member
'epicyclo » I reckon most road bike levers are far too flexy for disk brakes - you lose too much effort in flexing the lever.'
They feel perfectly fine until you replace them with a mtb lever, then you realise they flex.
Drilling holes? I suspect you must know me. 🙂
Posted : 28/08/2016 11:49 am
Funnily enough I've used both extensively, and the level of flex in either is well below the threshold of what you'd be able to feel. I reckon what you've felt is the difference in cable/system compression, added to the changes in leverage ratios.
Unless you were using mtb disc calipers with road levers. In which case you deserve all you get.
Posted : 28/08/2016 1:03 pm
...I reckon what you've felt is the difference in cable/system compression, added to the changes in leverage ratios.
I usually use tubing instead of cable outer so my system is virtually compressionless other than the short run to the bars, and it's when using that that the difference can be felt.
I do know the difference between the various lever pulls. 🙂
Posted : 28/08/2016 1:21 pm
[url= https://c2.staticflickr.com/2/1702/26616203305_8fa7053c19_b.jp g" target="_blank">https://c2.staticflickr.com/2/1702/26616203305_8fa7053c19_b.jp g"/> [/img][/url]
[url= https://flic.kr/p/GxYZWZ ]OK I will stop tinkering eventually, but you've got to admit these new #shimano #dxr levers look pretty sweet on my @traversbikes #RussTi[/url] by [url= https://www.flickr.com/photos/jimbosussexmtb/ ]Jim Barrow[/url], on Flickr
I've got TRP Spykes on one bike, I used Shimano DXR levers, purely because they were shiney, but they actually have a really strong spring in them so work well and I don't have any issue with them sticking. The only time I would say the brakes were any worse than a hydraulic was on some of the long descents, ten miles plus, on the divide. Then I did get aching hands and struggle to pull them. Super reliable though, which was exactly what I was looking for.
My Tripster has HyRd's on it and they are good, but TBH I'm thinking of changing to Spyres because the Spykes are so good on my Travers, I prefer the look of them too.
My "normal" MTB has XT's on it if that is relevant.
Posted : 28/08/2016 1:27 pm
