Measuring shock str...
[Closed] Measuring shock stroke length?
5 Users
Can I just measure the part of the shock that's exposed?
That's 57mm.
Or will it be less than this as some of the shock will always be left visible even at full travel?
I was sure my bike needed a 50mm stroke shock.
Posted : 13/05/2010 10:06 am
Length of exposed shaft (ooo-er) is correct.
Posted : 13/05/2010 10:11 am
 LoCo
200mm shocks can have either 50 or 57mm stroke, so it could be that the 57mm exposed shaft will only give 50mm travel.
What make /model/year is the bike?
Posted : 13/05/2010 10:13 am
zip tie or o-ring on shaft, deflate shock and fully compress, reinflate and measure distance from seal to ziptie/o-ring
Posted : 13/05/2010 10:16 am
 LoCo
If you tell me what bike it is I can just give you the info. 😀
Posted : 13/05/2010 10:32 am
As votchy said
Posted : 13/05/2010 11:08 am
