maxxis minion tubel...
[Closed] maxxis minion tubeless blowout
I'm pretty new to tubeless and got the flow rims with minion FR folding 2.35 tyres.
my 3rd proper ride out on them and I got a front wheel tyre blowout when cornering in a berm. I had 35psi in the front for my 100kg loaded up.
The tyre is difficult to seat with a track pump alone so I'm wondering if its a bit loose and this is why it blew off easily?
Its not a brand new tyre to this rim if that has anything to do with it? Or is a specific tyre/rim combo issue?
Posted : 05/03/2013 12:03 pm
 ffej
I'm surprised you've had issues with minions.. They are usually pretty reliable. I managed to rip a high roller off the rim years ago but that was due to running silly low pressures (sub 20) as I was too lazy to put air in. Could be historic damage to the bead?
I find all maxis tyres can be tricky to first seat onto the bead.. but once up they are fine.
Posted : 05/03/2013 12:37 pm
Are you sure it was fully onto the bead? Possible to get a tyre to seal up without being fully in...
Posted : 05/03/2013 12:40 pm
I manage fine at a similar pressure to you on exactly those rims. I´m about the same weight too. One thing that happens often when you are just on the first ride is that they´re not seated well and you gradually lose air through the day which eventually results in a blow out.
Posted : 05/03/2013 12:41 pm
I have had exactly the same problem, same tyre, same rim, same terrifying explosion on landing.
I find it happens with the folding ones but not with the wire bead ones, I think they are just a bit too floppy
Posted : 05/03/2013 1:04 pm
I'm sure it was seated fine. Maybe I'll give another go and double check the seating.
any tips to confirm correct seating?
Posted : 05/03/2013 2:23 pm
If it stays inflated over a day or so then it´s seated. You normally hear a distinctive "ping"! The sound of success.
Posted : 05/03/2013 2:45 pm
