Maxxis HR knobs and...
[Closed] Maxxis HR knobs and tyre sealant
6 Users
Hi All
2 things:
Maxxis HR2 - Exo 3c blah blah blah. Done less that 600 miles on it and a knob cracked to the extent it made a hole in the tyre! Is this normal? I'd noticed the knobs were cracking a little after a few rides.
Then went to put a tube in as clearly the sealant wasn't doing its job and all I found inside the tyres was some sealant boogers, is this normal, they were hardly liquid to fill a hole!
Posted : 01/08/2015 3:48 pm
 MSP
How long was the sealant in for?
Posted : 01/08/2015 3:51 pm
Mincing along towpaths no, rampaging down the alps and heavy braking/cornering, yes
After a few weeks no, after a few months in hot weather, yes
So basically, no or yes, depending on the circumstances, give us some more info!
Posted : 01/08/2015 3:55 pm
CO2 will do that to stans fluid too.
Posted : 01/08/2015 4:00 pm
Also if the original installer was tight with the amount of sealant when setting them up, a small quantity will dry up quicker
Posted : 01/08/2015 4:05 pm
50% xc type riding 50% alps and BPW
Had the bike for 3 months
Sound like I should check my sealant more often then!
Posted : 01/08/2015 4:31 pm
Yeah, 3 months of hard riding on the summer will use up your sealant 🙂
Also, the enlarging hole/s will have used up sealant, possibly without you immediately noticing.
Posted : 01/08/2015 6:08 pm
 MSP
Some makes of tyres soak up the sealant more than others, ie continental uses loads even after they are sealed, where as schwalbe barely seems to need any.
Posted : 01/08/2015 6:15 pm
