Maxxis EXO.
[Closed] Maxxis EXO.
4 Users
Are all the EXO tyres the same EXO?
I've been using an Ardent EXO on the rear and not had a punctures in ages.
Swapped to an Ikon EXO and had 2 snakebites in the sidewall of the tyre just above the bead.
So is the casing not as tough on the Ikon?
Posted : 26/05/2015 8:13 pm
 mboy
I think the casing is the same, but the Ikon has a lot less rubber on it per se. A normal Ardent is a fair bit tougher than a normal Ikon, so it stands to reason an EXO Ardent is a lot tougher than an EXO Ikon.
If that makes sense...? 😕
Posted : 26/05/2015 8:26 pm
The sidewalls feel the same though.
Not even a big drop or hard landing the second time round.
On the same side of the tyre both times.
Wander if it's faulty.
Posted : 26/05/2015 8:33 pm
The Minion and Ardent Race I have here are both Exo TR, the ardent race seems to have a thinner sidewall. No punctures from either, although am running both tubeless.
Posted : 26/05/2015 8:37 pm
I'm also tubeless...
Posted : 26/05/2015 8:40 pm
They are different. EXO refers to an extra layer in the sidewall construction, but the ultimate strength/puncture proofing depends on the original construction too.
Posted : 27/05/2015 6:41 am
Thanks Ben.
Looks like I'll put the Ardent back on then.
Shame as the Ikon is a great tyre just not tough enough.
Posted : 27/05/2015 4:02 pm
