Maxles - are old on...
[Closed] Maxles - are old ones and Maxle 360s interchangeable?
I've mangled my Pike Maxle a bit - battered off a big old rock and the lever is a bit bent together with the flanges beside the lever. It still works but you have to be very careful in closing it and to be honest I'd rather get a new one to put my mind at rest.
From a quick look at the tech documents it looks like I have a Maxle, but the spares are all Maxle 360s - anyone know if I can use a Maxle 360 as a replacement? The stuff talks about it being an upgraded axle so I reckon it would be OK but anyone know for sure?
Posted : 20/01/2009 2:28 pm
I don't see why not. The maxle 360 is just an upgrade of the lever design is it not? this allows you to close the lever at any angle. The rest of the axle is just the same.
Posted : 20/01/2009 2:58 pm
I [i]thought[/i] not.
Posted : 20/01/2009 3:26 pm
maxle and maxle 360 are interchangable, maxle lite isnt
Posted : 20/01/2009 3:48 pm
They are interchangeable.
I've got a spare lying around; its had only a few months use and Isn't a 360.
email me if you're interested.
Posted : 20/01/2009 3:53 pm
I vaguely remember reading that they aren't, but I have no idea as to why thats the case. Its got to be worth emailing RockShox to check though, as its a kinda important part.
Posted : 20/01/2009 3:56 pm
too many half baked opinions, so I'll qualify what I said:
Maxle and Maxle360 are definitely compatible.
I know this because I have both and I checked to see if they were.
Posted : 20/01/2009 4:05 pm
A search on MTBR shows it ain't that simple. Tons of details here:
http://forums.mtbr.com/showthread.php?t=232938&highlight=maxle+360+pike
All depends on the age of your Pike, if its an 05 you could hit some problems
Posted : 20/01/2009 5:04 pm
Thanks all. On investigations this evening, it would appear that my Pikes are 2007 forks so the damaged one will be a Maxle 360 anyway. Which would mean a new Maxle 360 will be just the ticket. Ahem.
Posted : 20/01/2009 11:06 pm
The maxle 360 off my totems doesn't fit my 2005 pikes with a normal maxle
Posted : 20/01/2009 11:09 pm
It works. The 2007 Pikes don't have a Maxle 360 as standard by the looks of things. The Maxle 360 works just fine though. Hurrah.
Posted : 29/01/2009 10:07 pm
