Mavic XM 119 rim di...
[Closed] Mavic XM 119 rim dimensions for spoke calculator on Alfine hub
 Ells
Hi,
I have been trying to a spoke calculator that has both Mavic XM 119 rims and 8-speed rear Alfine hubs SG501 so I can work out what spokes to order.
Any body got any ideas? Is there a rim that has the same dimension?
And I am presuming 2 cross is the way to go seeing as its such a large hub diameter?
Many thanks.
Posted : 04/01/2012 12:16 pm
Looking to build the same wheel.
What spoke size did you use in the end? Did you go 2 cross?
Thanks.
Posted : 29/06/2012 4:43 am
Using...
[url= http://www.shimano.com/publish/content/global_cycle/en/us/index/tech_support/tech_tips.download.-Par50lparsys-0015-downloadFile.html/08)%20Hub%20Dimensions.pdf ]Hub[/url]
[url= http://mtb.mavic.com/en/product/rims/mountain-bike/rims/XM-119-Disc ]Rim[/url]
2-cross
249mm both sides (32 hole)
246mm(L) / 245mm(R) (36 hole)
3-cross
265mm both sides (32 hole)
260mm(L) / 259mm(R) (36 hole)
Posted : 29/06/2012 7:16 am
Thanks but 249mm can't be right for 2 cross.
I built an Alfine 8 on Mavic XM317 disc 2 cross with 32 x 238mm spokes and the rims aren't that different.
Posted : 30/06/2012 4:03 am
