Mavic UST road rims...
[Closed] Mavic UST road rims and standard tyres.
Anyone tried Open Pro UST's with non-UST tyres?
Not bothered about going tubeless on road but I'm concerned normal tyres might be too tight to be practical. Don't want to get stuck with a flat and no easy way to remove the tyre.
Posted : 29/11/2018 7:30 pm
I've got Cosmic UST wheels with Vittoria Corsa G+ and I can just get them on using my fingers
Posted : 29/11/2018 7:32 pm
Watching with interest op, as I'm thinking of rebuilding some wheels with those rims.
Posted : 29/11/2018 8:07 pm
I've got a set of new mavic open pro ust disc wheels for sale if you want to find out? 😋
Posted : 29/11/2018 8:29 pm
Was going to say I like to build my own, but I'll send you a message tomorrow, would be daft not to know what you are thinking price wise.
And thanks Steve.
Posted : 29/11/2018 10:16 pm
No worries, to be honest they're no more difficult to get good supple clinchers on than the Fulcrum Quattros I had on the previous bike.
Posted : 30/11/2018 9:27 am
Don't use Open Pro but use DT Swiss R460DB which are tubeless with non tubeless Schwalbe Durano tyres and they are easy enough to get on.  I also run them tubeless and they went straight up and stayed up.
Posted : 30/11/2018 11:16 am
Standard tyres on tubeless rims are fine.  I wouldn't run standard road tyres tubeless though, not at 100psi, when they're not designed for use without a tube
Posted : 01/12/2018 10:44 am
I wouldn’t run standard road tyres tubeless though, not at 100psi, when they’re not designed for use without a tube
Why not, what do you think will happen?  100psi with a tube is still 100psi.
Posted : 01/12/2018 11:09 am
I'm planning on sticking with tubes. I don't have a problem with punctures in the Conti Sport Contact tyres I use.
I think the theory about tubes helping prevent blow-offs is the force of the tube holds the tyre bead into the rim hook.
Posted : 01/12/2018 11:52 am
My Ksyrium ust wheels arrived in the box from Mavic with standard tubes and tyres fitted.
Posted : 01/12/2018 12:01 pm
And if there is no rim hook?  I am not alone in using non tubeless tyres on a road tubeless setup with no issues at all.
Posted : 01/12/2018 12:10 pm
🤷‍♂️ Dunno. I never tied it, that theory was just what I read somewhere. Probably on here TBH, and we all know, like Wikipedia, info on STW is 100% correct every time. 👍
Posted : 01/12/2018 1:51 pm
I was just genuinely interested in what the reason was as not sure why a tube at 100psi would hold anything on more than just the air at 100psi without a tube.  Can really think why it would be different.
Posted : 01/12/2018 1:57 pm
