Mavic Crossmax SX w...
[Closed] Mavic Crossmax SX wheels on a 150 wheel spacing frame?
Any engineers out there?
I was thinking of running a pair of Mavic Crossmax SX's on a Morewood Kalulu. The Mavic's are 142 rear hub spacing and the Kalulu has a 150 rear hub spacing.
I will run an axle with 2x4mm spacers to make the 142mm hub the same size as a 150mm, so it fits into the frame. Any ideas why I shouldn't try this!
It might effect the chain line, I can't think of any other reason why not to.
Any opions are most welcome!
Thanks
Mark
Posted : 20/03/2012 9:22 am
 jedi
my 2012 crossmax sx are 135 rear as standard and i use them 12x142mm with the supplied spacers. are yours full 142??
Posted : 20/03/2012 9:42 am
Your chainline will be well off, and your rear disc will be well off centre too.
142 wheels are still pretty much 135 width - the extra 3.5mm either side is recessed into the frame, everything else is unchanged form 135 - so you're looking at both your chain and disc being 7.5mm out of line.
You could bodge the brake with longer bolts and loads of spacers, and live with the chainline - but I wouldn't.
Posted : 20/03/2012 9:46 am
chainline and caliper alignment, side loads on the axle
no sorry your right they are 135mm with the supplied spacers making them 142mm. So I guess making them 150 would be spacing them out further!
Probably to much I guess.
It's annoying as the deemax are a lot heavier and the crossmax are a good weight and still bombproof.
Posted : 20/03/2012 9:47 am
Thanks all, it sounds like a right cowboy thing to do then!
I guess I'll have to find some light weight 150 wheels.
Posted : 20/03/2012 9:56 am
I was going to suggest a Deemax hub, but I checked - the spoke counts are different, so it'd be far more hassle than it's worth.
Posted : 20/03/2012 10:08 am
Cheers for your help, I think I'll buy the full bike instead of the frame and live with the wheels it comes with.
Posted : 20/03/2012 1:11 pm
