Mavic Crossmax serv...
[Closed] Mavic Crossmax servicing taking up play in axle etc
I have a wheel I have had kicking about for a while. Its a Mavic Crossmax XL. Nice wheel but the axle pulls loads from side to side. I think it needs taking up the slack in it as I know you can adjust this with the Mavic wheel hubs. Any idea how to do this? It as like a big silver alloy nut thing with little holes around it on one side of the axle. I presume this is some preload thing? needing a special tool no doubt. I have taken the free hub off and that seems ok, its the axle that needs tightening up to stop it moving side to side.
Its a rear wheel BTW
Posted : 14/07/2011 2:02 pm
With the wheel in the frame (or forks) use circlip pliers/needle nose pliers in the holes and turn the ring clockwise to take up any play, don't tighten too much, just enough to remove the play
There is a proper tool but circlip/needle nose pliers work ok
Posted : 14/07/2011 2:50 pm
Do you have to have the wheel tight in the frame with the skewer? So there is no lock nuts or anything to loosen off?
Posted : 14/07/2011 2:58 pm
Yes, wheel fastened up as normal
This tool
http://www.tartybikes.co.uk/tools/park_spa2_pin_spanner/c31p11599.html
Posted : 14/07/2011 3:02 pm
