Hi
I have a rounded spoke nipple on an 819
looks like I need to remove the insert to get the nipple out? Is that right?
And what tool would I need - is it a 9mm I need?
ta muchly
Posted : 12/10/2012 2:37 pm
You need a spoke key (pretty sure it's 9mm) and one of these: http://www.chainreactioncycles.com/Models.aspx?ModelID=18081
More info here: http://singletrackworld.com/forum/topic/mavic-819-nipple-question
Posted : 12/10/2012 2:44 pm
Also worth noting that you need a longer nipple than normal, usually a 16mm, otherwise your spoke key may not reach, and the inserts in the rim have a left-handed thread.
Posted : 12/10/2012 7:23 pm
use loctite on the insert too.
Posted : 12/10/2012 7:29 pm
Hey Charlie, I use a set of plyers wrapped in duct tape. It's OK although it marks the inserts. Loctite for doing them up definitely. V. easy.
Hope you're well.
Posted : 12/10/2012 7:36 pm
