The infrastructure is the main problem and it seems like an easy fix
There's another, cheaper, simpler and immediately available fix.
[i]There's nothing to suggest the driver was on the phone. It's the cyclist that's put himself in danger here not the other way around.[/i]
Hence the 😉
It was debated YESTERDAY for [b]10 pages[/b], hence I'm not taking the SAME opinions being recycled too seriously.
[i]My AV just flagged that image up as dodgy btw.[/i]
It's your AV that's dodgy - it's just a jpeg on globalautotransportation.com
That's a fair assessment. Direct cause, indirect (latent) cause, contributing factors.
Still think that in that particular scenario there isn't much the HGV driver could have done differently. And he is quite right about constantly being told not to pass on the left, even up here we know that. By the look of it victim realised he ****ed up when the adrenaline wire off. Camera prat just seems the militant type.
Bruce - we're all cyclists here and that generally we're siding with the big bad truck driver should tell you something.
There is absolutely positively [i]nothing[/i] the driver could have done differently? In future if he finds himself in the same situation he should handle it in [i]exactly[/i] the same way? There are no lessons for him and other drivers to learn from this incident?
This explains a lot about the standard of driving in the UK.
Keep things the same and wait for Darwin to sort it out?
Speeder - ...filtering right and as such should have an expectation that there's no-one to his left or if they are there illegally, they have the sense to have gotten out of the way.
Well this is the point that some of the people here are trying to make. The driver is surrounded by cyclists and should adjust his driving to suit, he couldn't reasonably expect his left to be clear, he should be as sure as possible. He obviously didn't adjust his driving and certainly backed that up with his ranting afterwards.
So when can he expect his left to be clear? because even when he does get to the curb there could still be a cyclist right against his bumper.
Even though he was largely without blame if he finds himself in the same situation again then he could alter his behaviour by maintaining a constant speed through the pinch point rather than accelerating into it.
Or he can just keep accelerating into pinch points since there is nothing strictly speaking illegal about it
It's not about where a cyclist *could* be, it's about where they are LIKELY to be.
Cyclists are likely to be riding on the left by the curb, like they are on pretty much every single road in London. He's driving a large lorry, he should be aware of this. Accelerating away from the junction and moving to the left, leaving no gap near the curb, is not good driving, especially when that's where the blind spot of the lorry is.
Even if the cyclist wasn't in the left turn lane acting like an idiot, there could be other cyclists there.
I can't believe people think the blind spot has no effect here. Even if someone makes a mistake, you can't just drive into them when you can see they are there, so removing the blind spots would have an effect in reducing accidents.
Haven't read the whole thread, got the gist after page 1. The usual anti-cyclist stuff you see on here which is very peculiar for a cycling forum. Yes the cyclist was bloody stupid, but the truck driver knew there were loads of cyclists around (half a dozen of them cycling off in front of him), yet thought 'sod'em, they're not obeying the rules of the road, so I'm in the right and don't have to care'. If I'm driving and there is a blind spot, I assume the worst and drive accordingly rather than piling on regardless, which is what the driver did here.
STATO - So when can he expect his left to be clear? because even when he does get to the curb there could still be a cyclist right against his bumper.
Do what the tipper driver is doing in the streetview link that Speeder so helpfully provided. Move over into the merging lane (slow to let the equally impatient motorists stream past on the right if necessary) to leave some space at the curb just in case. Rather than carry on regardless and *hope* that you aren't going to grind a cyclist under your wheels.
No he can't .... in that same situation again he has cars on his right and behind as well.
The cars on his right can't see the cyclists and the cyclists can't see the cars on the right. The HGV driver has to consider the cyclists [u]and [/u]cars on his right [u]and [/u]cars coming in the opposite direction.
He doesn't have the luxury of exclusively watching some cyclists ...
Yes but in the next time it could be a slower cyclist, so it would end exactly the same way.
There are only 2 alternatives.
1. Remove blind spot, they shouldnt be there. But they are, infact in modern cars they are getting pretty huge too for drivers that dont bother to move their heads.
2. Slow significantly before he moved left, so that anything that had stayed in his blind spot was now moving much faster and travelling out of it (while also watching to make sure nothing went into it).
But of course 'this is London' so if he had slowed to move left you could expect the camera guy to dive up the inside and expect the driver to actually stop, or you would have had a load of cyclists going round his right side and then cutting infront.
The difference there is that the tipper driver is driving through the junction on green having come from a single file of traffic with a clear idea of what's going on around him not starting off from the inside lane from a standstill with a gaggle of impatient & mostly invisible cyclists illegally situated next to him.
FFS I give up - sense obviously isn't as common as I thought, even on here.
Radar - HGVs need radar - that'll solve it.
that almost always happens on here.
What it tells me is that even cyclists are not sympathetic to cyclists.
Whether or not you criticise the HGV driver, I think most or even all of us think that the primary responsibility for the accident lies with the cyclist, and that the cyclists using the filter lane were all in the wrong.
Given that most of us are experienced cyclists, I wonder how we would behave in those circumstances, after a period of time commuting by bike in London:
a. Gradually copy the other cyclists because of the difficulty of going against the flow and herd mentality (but make damn sure to either be fast enough to outsprint the HGV well before the pinch point, or hold back in the junction until it had passed and then slot in behind it)
b. Ignore the other cyclists and always take primary position behind the artic
c. Go over to the cyclists and tell them that they should not use the filter lane to sidle alongside the artic.
I am fairly sure I would do b., because it's clearly the safest option and I am an extremely cautious rider. I'd like to think I would do c., but I suspect that even if I did that the riders would ignore me and I would give up after one or two attempts.
If so many riders in London and elsewhere are cycling so dangerously, such that they are now no longer just a few bad apples but possibly the majority, how are they to be persuaded to change? The police probably do not have the resources to undertake major exercises on a large enough scale to influence enough of these riders to change. And the riders themselves do not appear to be receptive to being told they are in the wrong (Dunning Kruger effect?).
not sympathetic to stupid people...
I'm sympathetic to rucksack man, I'd hate to be in that position of being properly scared for my life but I'm objective enough to see that he brought it all upon himself.
Judging from his actions, attire, gear choice and general sense of awareness, he's not a regular cycle commuter and this has probably put him off for life and that's a shame. One can only hope he's self aware enough to watch the video back and say "I f****ed up there" rather than "that truck driver tried to kill me"
No I think most of us think what the cyclist did was bloody stupid. The responsibility though always lies with the person who poses the biggest danger to others, which in this case is obviously the truck driver.
So because he made a stupid decision he deserves to die and we shouldn't be at all bothered about it? 😕
Cyclist all at fault - that's a left only lane they were in. At least the girl had the sense to notice that there was a huge truck next to here and see the impending danger.
I just don't think that would actually work for big HGV's....
Assuming 90% of attention is on what's in front a full set of 360 cameras and sensors the remaining attention is then spread pretty thin.
I might be wrong but I think it would simply be an information overload and possibly lead to more accidents with the driver checking various screens.
We teach children not to step out to cross the road from behind parked cars because it puts them in danger of getting flattened by a car/bus/truck that hasn't seen them - this is just the same. The cyclist has wilfully ridden into the path of an oncoming vehicle from a position where he can't be seen with no regard given for his own safety and I can't fathom how anyone is apportioning blame to the driver. Other than the fact that he's not the vulnerable party.
He's driving a massive truck, with lots of blind spots in an urban environment where he knows there are loads of cyclists around, yet he still sees fit to accelerate into a pinch point after seeing lots of other cyclists overtake him on the inside. You don't think he maybe should have though that there might just be more, and slowed down to be sure? The fact that they are stupid and not obeying the rules is largely irrelevant.
Accelerating when the lights go green? Shocking behaviour!
The truck driver is responsible in that he managed not to hit any cars or force them into an oncoming bus.
You are looking at this as if it was a 2 party accident.
The HGV driver doesn't have that luxury... which is what a lot of people are missing. The HGV driver has to consider everyone else.
But does he deserve to live [u]at the expense of[/u] a car full of kids on the other side of the road?
Should the driver divert all attention to a possible cyclist when he has cars on the outside and then potentially swerve and knock one into the path of an oncoming bus?
Does the driver of the car behind deserve to die because they are too close if the HGV slams on the airbrakes?
dazh - Member
No.
I do get where you're coming from but it was the cyclist's accident to avoid. There are 9 other cyclists who managed to avoid putting themselves in that situation either by getting in front or hanging back (or filming) only this guy persisted in staying in the blindspot and then riding into the path of the truck.
The bloke filming was a bawhair from a similar collision, its only in light of the utter stupidity of the guy in front that his riding doesn't look so bad. This makes his cry of "I've got that all on camera" particularly pathetic.
Which is cobblers. Ultimately, what governs the rights and responsibilities of all road users is the law and the Highway Code, which exists to tell people what they may and may not do, and so make the roads safer by making people's actions compatible and predictable.
At the end of the day, it is the justice system that is the ultimate arbiter of responsibility under the law, and neither your nor my opinion will count (unless you work for the CPS, or one of us is on a jury). If that accident had resulted in the cyclist being killed, I very much doubt that the driver would have been prosecuted, because it would have been deemed the cyclist's fault.
That is childish logic. Indeed you seem to want to apply parent and child standards of responsibility for behaviour to road users: children are unpredictable and can run out into the road, and parents are responsible for them and have to prevent that and protect them. Grown ups have autonomy and can make their own decisions, but they also have to take responsibility for those decisions and enjoy or suffer the consequences as applicable.
completely agree - the truck driver would have known that the other cyclists were there but can only assume that they would be smart enough to stay back from the impending danger, like that lady.
Assuming 90% of attention is on what's in front a full set of 360 cameras and sensors the remaining attention is then spread pretty thin.I might be wrong but I think it would simply be an information overload and possibly lead to more accidents with the driver checking various screens.
Current situtation - driver looks forward and has to check 8 (?) mirrors.
Future situation - driver looks forward and checks one screen (with mirrors in case the system fails).
What is more likely to result in "information overload"?
FWIW... this is the sort of thing I am talking about
So a drone for every truck then?
Completely agree but IMO drivers of trucks in conditions like that should operate at a higher level of skill, awareness and responsibility. The way he accelerated into the pinch point I wouldn't have done in my car, let alone a truck. I can understand the truck drivers reaction but I would argue that if a truck driver couldn't deal with that situation without hitting a cyclist then they probably shouldn't be driving a truck in a difficult urban environment.
He doesn't. Our hero with the camera brakes. It the frame of reference that makes the truck look like its accelerated
It's not a drone. It's a reprojection of fisheye images from cameras mounted on the front, sides and rear of the car/truck onto the ground plane.
It doesn't need electronic devices to fix the blind spot issue just a cab at the height of other road users.
Although I would probably suggest that that size of vehicle should be in the centre of a city either.
Unless the guy who got hit also brakes at the exact same time as the guy with the camera then no, the driver accelerated into the pinch point.
Most likely he was doing that because he had a line of cars accelerating like mad to get to the traffic island before him and cut him off.
Which they were doing because the road design is ****ing stupid. One lane for straight ahead and a full size filter lane would have meant that this probably wouldn't have happened.
Im amazed that people are saying the driver is at all at fault.
typical of todays society imo. Ive hurt myself and it must be someone elses fault....
So in the spirit of accepting I might be wrong, I watched it again a few times. This time with the sound on. Seems to the following exchange is very illustrative of the driver's mindset:
cyclist with camera: 'Mate you knew there were cyclists there'.
Driver: 'I don't give a ****, you were in the wrong lane'.
Can't say I've changed my mind.
Ah but the driver was accelerating.
From a standstill. Whodathunkit? 🙄
I don't think anyone is saying the driver is at fault. I'm not sure if it's a road thing or if a society in general thing but there seems to be a need to attribute blame 100% one way or the other in any accident. In reality there's normally one person who is mostly at fault, in this case the cyclist who put himself into a very dangerous position, and the contributing person, in this case the driver who accelerated into a pinch point.
And then there's the environment factor which in this case is a really stupidly designed and dangerous junction which has a filter lane that you don't really notice until you're in it and a two lane into one within meters of the junction which meant the HGV driver was accelerating into the pinch point to stop himself being cut off by a line of cars racing up on his right.
So, main factor, cyclist being stupid. Contributing factor to that was the driver accelerating into the pinch point. And the contributing factor to that was the line of cars racing up his right side. And the contributing factor to that was the stupid ****ing road design.
Ah but the driver was accelerating.From a standstill. Whodathunkit?
Look at the video again. He was maintaining a constant speed/accelerating slowly moving across the junction. Then there is a sudden increase in his speed relative to the cameraman and the rucksack guy as he enters the pinch point. He was probably trying to beat the cars trying to cut him off from his right.
Maybe it's just me, but I tend to try and avoid running people over regardless of who's at fault.
Current situtation - driver looks forward and has to check 8 (?) mirrors.Future situation - driver looks forward and checks one screen (with mirrors in case the system fails).
My OH's car has multiple sensors and rear camera.... the first thing I do when I drive is turn them all off (All the times I've ever driven her car only ever driven to the local sainsbury's that is reverse parking in very tight spaces )
I'm perfectly capable of putting the car in a gap 6" longer than the car but no way can I do it with sensors going off everywhere and a distorted camera view.
My OH however struggles to stick it in a gap 6' longer than the car either with or without sensors/camera.
I'm not saying it can't work... but I am sceptical... Most HGV drivers are experienced and know the size of their vehicle - to take the parking analogy more like me than the OH...
[quote="Driver:] 'I don't give a *, you were in the wrong lane'.
I think the driver is understandably quite shaken....
I think you are choosing to believe the driver is saying it's OK because they shouldn't be there ...
I believe the driver is saying he doesn't Fing care if it's London etc. that he didn't see the cyclist [u]and the cyclist should know this[/u] because of all the awareness campaigns...
whether he did or didn't ...
He was probably trying to [s]beat[/s] not crush the cars [s]trying to cut him off from[/s]on his right
well it got past the cyclist it hit and i think we can all agree things from stationary accelerate away from a stationary start.Our hero with the camera brakes. It the frame of reference that makes the truck look like its accelerated
Why you calling him a hero? all it does is make me question your impartiality.
I'm believing what I heard, not what I want to hear because it fits with my opinion. It's quite clear what he said, and what he meant, so I don't know why it's up for debate.
When the cyclist started shouting (ie the first moment he had any idea the bloke existed) the driver swerved away from the curb. His reaction was what I'd expect from someone that's come that close to inadvertently killing another person. Just because he knew he'd ridden up the inside (obvious) doesn't mean he tried to kill the guy to "learn him".
I think the driver is saying...
"I don't want your death on my hands just because you're an idiot"
Really? I may have been hearing things but what I thought he said when challenged on the fact that he knew there were cyclists on his left hand side, was 'I don't give a ****, you were in the wrong lane'. Maybe I'm being overly critical but if a driver had said that to me after hitting me from behind then i wouldn't be overly happy.
I'm not impartial. I'm a regular bike commuter I'm predisposed to side with the guy on the bike. Unless they do something so obviously fkn stupid that its almost impossible to defend.
I may have been hearing things but what I thought he said when challenged on the fact that he knew there were cyclists on his left hand side, was 'I don't give a *, you were in the wrong lane'.
Listen again....
He is told "this is London, there are always cycles on the inside"
to which he replies "I don't give a *, you were in the wrong lane"
he then goes into the fact information is widely available NOT to do this.
I agree with southern yeti .... that is how I interpret this.. but I am willing to see there are other interpretations...
I'd go beyond Southern yeti and say what the driver is trying to express is that
"you just nearly got yourself killed doing something that is widely publicised as a good way to get yourself killed and is illegal [b]and you are shouting at me[/b]" .... hence the not giving a ****....
but that's my interpretation partly based on the driver swerving away when he impacted and the general confusion created by the "camera guy" and how I've felt when someone has through their own stupidity nearly caused a serious injury then started shouting at someone
Only Sunday I encountered 2 riders going the wrong way along a one way trail.
After flying down with my kid they then shouted at us for essentially them going the right way and having to get out of our way ..... I was still in shock from their sudden appearance round a blind bend whilst I had no wheels even on the ground... what do they want me to do brake in mid-air???
Despite being with my kid (and not usually acting like this or saying **** in front of my kid) told them they were going the f**cking wrong way so shut the **** up ...
[b]The irony[/b] being I was angry and upset because I'd nearly hurt them... but they had accused me of behaving irresponsibly... but shouting accusations at someone who is actually in the right when their concern was you could have hurt/killed them is a bad start.
I regretted what I'd said 10 minutes later and explained to the kid I was very upset because I was scared I was going to hurt them but shouldn't have said what I did but at the time
That's it, you've hit the nail on the head. I don't know why you're all getting so hung up on what's said afterwards.
NOTHING they say to each other for the first 5-15+ mins after this event is going to be coherent.
- One's just been hit and quite lucky to have not been killed frankly on a normally mundane commute.
- The other has just nearly badly hurt/killed someone while working.
When was the last time you had a very close call with a 1+ton piece of machinery when out on your bike. Once that flight or fight adrenaline kicks then whatever you say in the initial moments is not you/ how you normally conduct yourself.
I think this does apply to a lot of the interaction after, including the lack of reflection on the part of both the cyclist(s) and the driver.
I wonder how it may have panned out if Muppet man with the camera hadn't have been there to antagonise the driver with his frankly ridiculous comments.
At the end of the day the cyclists acted like dickheads and I would say 100% the fault of the cyclist. He created the entire situation by being where he was. If a car had done the same thing this thread would have been two pages at the most. Did he deserve to get hurt, of course not, nobody does. Genuinely hope he's learnt from this bad experience and will stop dicing with HGVS as a result
All those cyclists should be forced to join the Tuffty club.
Is it time for co-drivers in london? One to drive and one act as spotter?
People keep mentioning this sort of thing, but think it through. How on earth would it work in practice? In aviation you have two pilots, but they are highly trained, in a predicatble evnvironment and there is a lot of work on how they perform together. You can't just have some bloke yelling "Bike on the Inside!!" or whatever. Apart from anything else think about the legal implications. Who is to blame if the spotter doesn't spot or the driver reacts and hits someone else. Non starter.
Funny, just seen the STW feed on Facebook - under vid says "Lorry in a hurry from the lights side swipes a cyclist
YOUTUBE". 😆
Glad to see the cyclist wasn't injured. Hopefully looking at the footage he will realise how stupid he was. How can the truck driver possibly see whats going on in his blind spot.
This is London?
THIS IS SPARTAAAAAAAAA!
lol **** cyclists
