Marzocchi Marathon ...
[Closed] Marzocchi Marathon Corsa SL WC 2008 - Air Pressures?
Hi all,
Just bought an used (but only 12 rides) fork - see title for full name ๐Ÿ™‚
I've been trying to figure out the air pressures in both pos. and neg. chambers but I don't quite think I got it right so I'm hoping for a little help and advice from you guys.
I'm about 81 kg and 186 cm of height and the current setup is:
Bottom valve: about 130 psi
Top valve (SFA): about 45 psi
The TST-micro is set around to turns from lock-out and the rebound is 3 clicks from minus (-)
Is this all wrong, or what would you recommend?
Thanks from a confused Dane ๐Ÿ˜€
Posted : 28/09/2010 7:17 am
