Marzocchi Dirt Jump...
[Closed] Marzocchi Dirt Jumper CSU
Anyone know where I can get hold of a Crown Steerer Unit to fit a set of 2015 Dirt Jumper 1 forks? Only place I can find is Windwave but new they are £200 which is more than I paid for the forks.
I bought the forks second hand and the previous owner must have been a bit over keen cutting down the steerer! The part number is 818558. Quite a few Marzocchi forks from 2010 on use the same part (DJ1/2/3, Four Cross).
Anyone have one?? Or maybe someone has a set of forks with knackered lowers or internals laying about that has the same part?
Posted : 04/01/2018 12:03 am
Could look into a lower stack headset and stem if its a few mm you are after.
Posted : 04/01/2018 9:41 am
Unfortunately after a bit more than a few mm.. only way I could make it work with a stem and headset is if you could still get hold of the really low stack crank bros iodine headset and a 25mm stack stem.
Posted : 05/01/2018 5:18 pm
