Marzocchi 55CR trav...
[Closed] Marzocchi 55CR travel reduction 170 - 150
Hi,
Can anyone point me to instructions of how to reduce marzocchi 55CR from
170-150. There is a spacer apparently, cheers .
Posted : 16/11/2014 8:46 pm
[url= http://singletrackworld.com/forum/topic/internal-spacer-swap-on-marzocchi-55-cr-2012-fork-1 ]http://singletrackworld.com/forum/topic/internal-spacer-swap-on-marzocchi-55-cr-2012-fork-1[/url]
Posted : 16/11/2014 8:52 pm
if you bought the fork new then you should have got the spacer with the forks. if you havent got it then your marzocchi dealer should be able to get you one.
i heard a rumour a while ago that marzocchi may also be bringing out a smaller spacer that will drop the travel to 160mm. still waiting for windwave to confirm this.
Posted : 17/11/2014 1:08 pm
Thanks for this , still pondering on whether to buy pikes or marzocchi , marzocchi seem
To have a great warranty and I'm not convinced by the new bladder thingy on the pikes. Sounds like a servicing nightmare .
Posted : 17/11/2014 5:20 pm
FYI the Marzocchi damper has to be bled if servicing.
Posted : 17/11/2014 5:24 pm
