Marzocchi 03 Z1 fre...
[Closed] Marzocchi 03 Z1 freeride service manual please anyone??
Has anyone got this electronically they could send me please or a link to where it might be found??
Your help would be much appreciated!!
Thanks!
Posted : 25/11/2013 3:33 pm
Thanks for your help Matt! Unfortunately those links are for web pages that don't exist anymore....I've searched myself believe me!!
I gather that Marzocchi won't send them out either if you contact them.
Does anyone have a tech manual for the above please?
Cheers!
Posted : 25/11/2013 6:57 pm
Swirly - the owners manual is on the Marzocchi website archives, e.g.
http://www.marzocchi.com/template/detailProdotti.asp?LN=UK&idC=1592&IdFolder=113&idMY=2147&IdOggetto=2441
Click on the 'Owners Manuals' tab on the right hand side and you can open the Pdf.
Posted : 25/11/2013 7:23 pm
Thanks Bennyboy....unfortunately this is the 'owner's' manual...I require the *service* manual as am stripping and rebuilding the fork.
Anyone please?
Posted : 25/11/2013 8:44 pm
 jeff
Got an exploded parts diagram here - any good?
Posted : 25/11/2013 10:02 pm
Send me an email (in my profile), think Ive got one on my works computer I could email tomorrow. However, it's for 2005 forks. Although internally, they'll be very similar.
It's not tricky anyway, just undo all the bolts and pull them apart.
Posted : 25/11/2013 10:55 pm
Actually, you tried this? http://www.birota.ru/manuals/marzocchi/index.php
Posted : 25/11/2013 11:06 pm
Thanks David the link doesn't work as files aren't there when you go to the site unfortunately...and thanks for your offer of help..have e-mailed you.
Thanks all for help looks like I now have the document I require or something from 2004 anyway...should be ok.
Ride safe!
Posted : 26/11/2013 10:50 am
Update to all those interested....
A special 12mm socket is reqd for recessed footnuts so either a ground down socket or box spanner might be needed as David Tayforth helpfully pointed out. ๐Ÿ™‚
Also thanks to Tandem Jeremy for his help and advice...much appreciated! ๐Ÿ™‚
Cheers!
Posted : 28/11/2013 11:14 am
I used a box spanner and files it down. It was a cheapo one made from fairly soft material so it wasn't to much of a chore.
Think I sold it with my last set of marzocchis. otherwise you could have used it.
Posted : 28/11/2013 11:36 am
I discovered a 1/4" drive 12mm socket in one of my sets that just about squeaked in without requiring any grinding, it is amongst my most valued tools and I would consider killing anyone who took it...
As for a service manual, I too have struggled to find them in the past, typically I just google until I can take no more, get the oil volumes from the Marzocchi website then go for the "methodical disassembly" method...
Posted : 28/11/2013 1:56 pm
