Mahle i35 and Iwoc ...
Mahle i35 and Iwoc - will not turn on
Bike was put away fully charged and turned off. Stored indoors.
Two weeks later = will not turn on at all.ย
When plugged in to the charger in get a solid white light, not flashing 'charging' light. When plugged in I can get it to flash green three times, but it refuses to turn on or connect to app.
Any ideas or suggestions?ย
Posted : 04/04/2026 12:24 pm
Can you take the battery out and leave it disconnected for a while?ย  clean the battery terminals?
Posted : 04/04/2026 12:39 pm
Can you communicate with the mahle hub using the mahle app?, or try a forced reset which is a 30second hold of the top tube iwoc button
If that doesn't work then disconnect, clean and connect all connections to the hubย
Posted : 04/04/2026 1:23 pm
