Magura Louise Brake...
[Closed] Magura Louise Brakes - is BAT in the levers only?
Just found a cheap opportunity to buy a pair of Magura Louise BAT brake levers, these are the blades only, not the master cylinder assembly.
Can I fit these to a set of non-BAT master cylinders to give BAT functionality?
Thanks
Posted : 28/11/2010 3:03 pm
Hi Paul, there shouldn't be any problem, as long as the lever bodies are the same. The BAT funktion is in the lever blades. The lever blades are also retro-fittable from the model year 2007 onto the the Louise, model year 2004 upto to 2007. The current model of Louise is interchangeable among the Louise model range from 2008 to now. Hope this helps? 8) You can get more help on Magura.com
Posted : 29/11/2010 10:05 am
Nice one, cheers.
Posted : 29/11/2010 10:09 am
