Made of cheese?
Made of cheese?
So, I'm needing a replacement of my Garburak 38t oval chainring for my GRX chainset and paying £75+ is a touch pricey for something that is going to be subjected to the winter gloop.
I've seen these online which are noticable cheaper, but I've never heard of the make, will I regret it if I buy one. Anyone have experience of Stone components?
https://nl.aliexpress.com/item/4001102806043.html
Posted : 22/10/2024 12:09 am
Right, I'm buying a chain-ring from AliExpress, what's the worst that can happen?
Posted : 22/10/2024 3:25 pm
Be interested to see how you get on as I'm using an equally spendy Wolftooth one and not looking forward to wearing it out.
I did briefly own a Garbaruk one, but it had a weird offset in it which didn't clear my frame.
Posted : 22/10/2024 3:45 pm
Went to order a 38t (for my puny legs) but they don't have any. So looks like it's a spendy Wolftooth one for me.
https://www.merlincycles.com/wolf-tooth-elliptical-110-bcd-4-bolt-chainring-for-shimano-grx-228777.html
I'm actually thinking it would be cheaper to buy a different crank set in the long run, one without proprietary rings.
Posted : 22/10/2024 4:22 pm
weeksy and weeksy reacted
 Yak
Wow, £75 for the cheapest aftermarket grx chainring? Bonkers. Must be the bolt spacing or there would be a superstar or uberbike one by now.
Posted : 22/10/2024 5:16 pm
 a11y
I’m actually thinking it would be cheaper to buy a different crank set in the long run, one without proprietary rings.
Definitely merit in that. When the proprietary direct-mount chainring on my Deore M6100 cranks on one bike wears out, I've got an £11 adaptor to convert them to 4-bolt 104bcd allowing greater/cheap choice of chainrings: https://www.ebay.co.uk/itm/315718545125
Already do similar on my gravel bike: blingy Hope EVO cranks, Hope adaptor, and a <£10 steel N/W chainring from eBay which is lasting brilliantly:
2024-09-11 Cotic Cascade morning biking 00007
Posted : 22/10/2024 5:20 pm
igm and igm reacted
Didn'thurt I've got a 36t Superstar Raptor you could have if you can deal with the increased cadence! I needed a ring with an offset as am using 2x cranks, so I think I'm committed to Garbaruk.
Posted : 22/10/2024 5:42 pm
Just saw this. Superstar wouldn't commit to their rings fitting GRX, but suggested they might. Mine did. Don't know why they were so evasive about it.
Posted : 22/10/2024 5:43 pm
@a11y  which one of those in the link do you use for the Hope cranks? How do i choose?
Thanks
Posted : 22/10/2024 6:10 pm
 a11y
None of them unfortunately - ML-008 is the Shimano direct mount one I use on Deore cranks, but nobody other than Hope make a suitable adaptor for Hope cranks. Hope one's a bit more than £11...
Posted : 22/10/2024 6:17 pm
Argh!! Thank you!
Posted : 22/10/2024 8:51 pm
Careful now, you're opening a can of worms/rabbit hole. I started with AliExpress chainrings too. But last year purchased a Shimano Alivio FC-MT210 triple chainset for my commuter. I sometimes do small drops max 18" on it, or try and ride over something that a commuter bike probably shouldn't ride over and end up jumping off the bike. Probably a contributing factor to the driveside coming away such that there's about 5mm of side-to-side play in the cranks. Yes it's definitely the drive-side and not a loose non-drive-side. Never happpened with UK bought Deore triple cranksets and I've run them for years and years and years, (and converted them to 1x).
Posted : 22/10/2024 9:41 pm
daviek and daviek reacted
 poah
what about road chainring. 105 should fit as its 110 BCD asymmetrical. Merlin have a 39t for £15
Posted : 22/10/2024 9:46 pm
Thought this was an e13 (the hubs were fine) thread but taking note as I've GRX single chainring on my new Sonder Camino.
Posted : 22/10/2024 10:46 pm
Has anyone tried the Alugear stuff, another polish firm, a slightly cheaper Garbaruk, some interesting looking chainrings.
Posted : 22/10/2024 11:02 pm
