lyriks - no rebound...
[Closed] lyriks - no rebound or damping
5 Users
loud top out clunk, whats the problem?
Posted : 30/07/2011 5:05 pm
They're broken.
Posted : 30/07/2011 5:07 pm
no shit sherlock
Posted : 30/07/2011 5:25 pm
Check the oil level on the damper side, which version of lyrics do you have
Posted : 30/07/2011 5:41 pm
coil uturn 160s with mission control
Posted : 30/07/2011 5:45 pm
Right - you've had what i had. Take lowers off and you will have all the oil in the lowers. The seal inside the rebound tube assembly will be gone.
A £20 kit from TFT will sort you out. I did mine no probs.
All the oil from inside your dampener will be in your lower leg.
Feel free to post me any Q's
EDIT:
[url= http://www.tftunedshox.com/Catalogue/Shop-RockShox/RockShox/RockShox-Fork-Spare-Parts/Lyrik-Damper-Service-Kit-RS114015087000 ]linky.[/url]
You will need the small fat one in the bottom right - the rebound cartridge slides up inside a thicker tube this seal is what separates the damper oil from going into the lower.
You tube videos available and they show you what to do - although apparently there are two types of rebound assemblies depending on age.
2nd EDIT:
[url=www.sram.com/_media/techdocs/07_RockShox_SPC_Lyrik_B%20Print.pdf]SRAM Technical manual[/url]
The seal is in the bottom of part no.10
Posted : 30/07/2011 5:58 pm
cheers carbon - thats what i hope
Posted : 30/07/2011 10:10 pm
Just stripped and cleaned them. No extra oil in the lowers, oil seemed ok in the damper.
New oil and greased seals, rebound is working again - wonder for how long though?
Posted : 31/07/2011 10:47 am
Final aoddness - in the rebound shaft the rebound alan key is firmly stuck in the damper, the head comes off (red bit) so i can get the foot nut out, any ideas of how to remove this?
Posted : 31/07/2011 10:48 am
my Boxxers did that - pliers/molegrips + force
Posted : 31/07/2011 10:52 am
any more advice on either issue?
Posted : 31/07/2011 6:04 pm
