Lyrik Mission Contr...
[Closed] Lyrik Mission Control DH oil height / amt
[#1562167]
Anyone know how much oil should be in a 2010 Lyrik 170 Coil with the Mission control DH damper?
Doesn't seem to be mentioned in the SRAM tech manual....
Posted : 30/04/2010 4:37 pm
can't help you with the oil amount, but would be interested in your opinion on the forks.
Posted : 30/04/2010 9:33 pm
at the moment I'm wondering if there's enough oil in the damper - I don't want to open it up until i know how much there should be. There's very little detectable difference between fully on and fully off compression damping - hence my first post - but i do like them.. however they are blowing through the travel pretty quickly.. but that may be an oil level issue.
Posted : 30/04/2010 9:59 pm
These forks rock when dialled in.
Posted : 30/04/2010 10:02 pm
vikingboy - can you easily spot the difference between the compression being wound right in or right out? I was expecting it to be super stiff when wound all the way on - but can't really tell any difference... is it subtle? or is there something up with my fork? Rebound goes from super quick to super slow - but compression is almost not detectable in the carpark!
Posted : 30/04/2010 11:04 pm
I find there is a bigger difference with the adjusters on the Lyric DH then on my previous Fox RC2, meaning you should definitely notice a difference. How does your rebound damping work?
It's not really unheard off that forks would ship with low lube oil, but usually they do manage to get enough in the dampers...
Posted : 30/04/2010 11:14 pm
that's what I thought.. once I find out the oil level needed I'll take a look and see what's going on...
rebound is fine - adjustability is there - super slow to super fast and all levels in between.
Posted : 30/04/2010 11:27 pm
The adjusters on mine make a lot of difference,especially the low speed compression
Posted : 30/04/2010 11:36 pm
Couldn't find an oil height / amount - so did some experimenting.. too much oil just means you don't get full travel. no effect on the damping (i.e. still none) - there's a slight notch on my 'Glide ring' - not sure if I put it there taking the damper out or it was there in the first place - could explain it. Ordering the damper service kit with a new glide ring - so will see if that makes any difference...
Both damper adjustments seem to be working mechanically (i.e. I can see the low speed valve open and close, and the high speed spring getting stiffer - so it must be a leak caused by the glide ring - or some other sort of fault with the damper..
Posted : 03/05/2010 11:08 am
