lyme disease
[Closed] lyme disease
 rone
[#3804287]
http://www.tickbitepreventionweek.org/index.html
I got bit last year doing c2c. Not 100% sure but felt rough on and off for months.
Getting sorted now. Anyone else had this/living with it?
Posted : 24/03/2012 9:15 am
Sounds like somthing you would watch on House MD
Posted : 24/03/2012 10:02 am
This is from about 2005...
http://singletrackworld.com/wp-content/uploads/2009/06/lyme-disease-everything-you-wanted-to-know-and-stuff-you-wish-you-didnt/
... and sadly needs an update.
Posted : 24/03/2012 12:35 pm
My wife caught it two years ago - i'll dig out a pic in a bit....
as she has an SLE lupus, amoung other things, and is on iummunosuppessants (she has no immune system), she was in hospital for about 2 weeks...
edit: here you go...
Posted : 24/03/2012 1:39 pm
Had it twice, both times self diagnosed and then agreed by the doc, 2 weeks of penicillin seemed to cure it.
Very common over here with climbers, bikers, walkers.
Posted : 24/03/2012 4:51 pm
My wife is a clinical pharmacist and I was skimming through her March Pharmaceutical journal and spotted an article on Lyme Disease. A condensed version here...
Borreliosis is the most common tick-bourne disease in the UK. Diagnosis is often difficult because the disease can produce a bewildering array of symptons, most of which resemble other diseases. Doxycyline is the treatment of choice for adults.
Once a tick has attached itself to the host it is important that it is removed correctly, as incorrect removal can lead to further complications. If the tick's head remains attached, abscesses can form, and squeezing the abdomen can result in the tick's stomach contents entering the hosts bloodstream, which can lead to septicaemia. There are only two safe ways to remove a tick - with fine-tipped tweezers, or with a tick-removal tool.
Posted : 24/03/2012 8:32 pm
Yep, got bit roughly end of May last year. Ruined my life (and cycling)
being treated privately since Feb and fingers crossed well on the road to recovery (Babesia cured hopefully)
Posted : 24/03/2012 8:33 pm
Holyzeus - Babesia or Borrelia ? (or both ?)
[url= http://cid.oxfordjournals.org/content/43/9/1089.full ]fairly comprehensive review[/url]
(Lyme's a controversial subject and other opinions certainly exist: I attended a talk once, given by the guy who chaired the IDSA group that produced this ^ guideline - he's had death threats and attempts to have him struck off because they said that chronic infection doesn't seem to have any supporting evidence, so long-term antibiotics should not be required)
Posted : 24/03/2012 8:48 pm
Both, Babesia is a co-infection. Potentially much more dangerous than Lyme but much easier to treat
Posted : 24/03/2012 8:53 pm
Can I (rudely) ask what you're being treated with, for how long, and how much it costs ?
(feel free to decline)
Posted : 24/03/2012 8:58 pm
No problem, but privately. Email?
Posted : 24/03/2012 9:02 pm
mine's in my [url= http://singletrackworld.com/members/scaredypants/profile/ ]profile[/url]
Posted : 24/03/2012 9:05 pm
I'm doing something wrong, two failure notices..., mines roofer1 AT btinternet DOT com
Posted : 24/03/2012 9:20 pm
I've been feeling run down for years
often with bouts of sore glands in my neck, back of knees and groin
also having difficulty sleeping with night sweats etc
I guess its worth looking into
Posted : 24/03/2012 9:22 pm
YHM
Posted : 24/03/2012 9:25 pm
Alternative viewpoint, start here...
http://www.lymediseaseaction.org.uk/
... and I think I'm proof of the value of long-term treatment. Or maybe '[i]I would have got better anyway[/i]'.
Posted : 24/03/2012 9:27 pm
jools
That sounds familiar.
Posted : 24/03/2012 9:28 pm
Jools
My advice is to thoughly research Lyme first, there are many different symptoms at different stages. You need to see what symptoms you've had/still have to make a connection if there is one.
It is VERY unlikely you'll get anywhere with the NHS
Posted : 24/03/2012 9:53 pm
so the private route is the best way to get a diagnosis?
Posted : 24/03/2012 10:19 pm
That's how I got treated, jools. My GP gave me a month's doxy. It took lots more from someone I saw privately. You might start with Eurolyme, unless anyone here has newer info.
Posted : 24/03/2012 10:27 pm
Eurolyme is extremely helpful and a constant source of info.
Private treatment is really your only route, they will diagnose you clinically using testing as a guide and backup
Posted : 24/03/2012 10:54 pm
I've had 3 ticks recently - I successfully removed them sll by tying thread round the front part of their bodies and pulling them out using steady pressure on the thread - I was afraid of using tweezers in case it caused them discomfort which would result in them discharging their diseases into my bloodstream.
Posted : 25/03/2012 12:44 am
Removing a tick seems to strike the fear of god into many...I find they come out very easily. I just use tweezers, but I only use enough pressure to grip the body, then I pull gently until I can see my skin lift slightly, and they just seem to let go. Then I have to try and catch them as they normally start running up my arm 😯
Posted : 25/03/2012 7:55 am
As I posted back in 2005, I had all the symptoms of Lymes, was constantly feeling run down but had tested negative for Lymes.
Continued to feel like this for another 5 years and finally gave up on NHS, went private and was diagnosed with severe toxaplasmosis and gluten intolerance. Probably got the toxaplasmosis from living in France. Normally harmless but my immune system was severely compromised by the underlying gluten intolerance.
Having those private tests literally turned my life around.
Couldn't recommend private tests highly enough if you can afford it.
Posted : 25/03/2012 8:04 am
For those that get Tick's regularly - get one of these - its a standard part of my trail kit now.
http://www.tickremoval.co.uk/tickremovalshop.html
Posted : 25/03/2012 5:13 pm
I don't recall being bitten but have felt horrible for years
Went to breakspeare clinic in Hemel Hempstead a month ago
Just got the results, they did 4 tests for Lyme, 2 of which came back positive
Just glad I'm not mental as I kept being told my symptoms were psychological
Posted : 23/06/2012 2:55 pm
Jools, you're lucky you got in. They aren't taking on any new patients.
Who are you seeing there?
Posted : 23/06/2012 3:59 pm
Dr Puri
It wasn't cheap. At all
Posted : 23/06/2012 4:19 pm
It wont be but they are the only people in the country that can help you
Posted : 23/06/2012 5:17 pm
 Taff
Got an appointment with the quack on friday. Had a bite back in June and removed the tick, no ring, nothing at all. Now have a load of very similar symptoms to Lymes disease. Thought I had an issue with my thyroid medication at first as there were some similar symptoms but bow not so sure.
Posted : 22/08/2012 1:41 pm
I'm thinking of asking for a blood test at the end of "the season" just to make sure I'm clear. Think a GP will authorise that without evidence of symptoms?
Posted : 22/08/2012 1:42 pm
 Taff
No idea, reading similar topics it would seem that the tests don't necessarily pick it up and that people have gone for years without having it diagnosed. Seems a few had gone private and then had it sorted immediately
Posted : 22/08/2012 1:53 pm
This ^^
Posted : 22/08/2012 2:42 pm
 ojom
From experience, the tests are not conclusive.
There are doctors out there though that can assist. PM if you would like a name.
Posted : 22/08/2012 2:44 pm
[quote=thebikechain ]From experience, the tests are not conclusive.But more conclusive than not having one at all....
Posted : 22/08/2012 3:07 pm
Lyme is primarily a clinical diagnosis
Taff, be proactive NHS is next to useless
Posted : 22/08/2012 7:59 pm
ah didn't realise you're supposed to pull and wait for tick to let go. i always just ripped them out.
right?
btw cards are slightly cheaper (3.95) on ebay.
Posted : 22/08/2012 8:17 pm
 Taff
Well I'm having tests done. Had a load of blood samples done on Friday and GP was worried and wanted to sign me off work! Can't walk up the stairs now without feeling tired but hopefully will be ok soon. Doc thought it was either Lymes or rheumatoid. Marvellous. Been told to stay off the bike which seeing as I can't walk the stairs I hasn't planned on doing anyway. Got a trip to Leogang next week and really hope I'll be ok with that
Posted : 26/08/2012 8:52 pm
I have always been told to drop candle wax on them or daub cream over them so they cannot breath ?
Apparenly they breath out of their arrass so in order to carry on munching they exhale through the back end and in dropping wax on them it takes its head out and they come out in one and are stuck in wax so you can check the head is still attached ?
Posted : 26/08/2012 9:11 pm
[quote=scbutcher ]I have always been told to drop candle wax on them or daub cream over them so they cannot breath ?
Bollox.
Get a tick remover tool and do it properly. Anything which stresses them can cause them to empty their stomach contents into your body - which is how you can contract Lymes.
Posted : 26/08/2012 9:14 pm
Does the tool strangle them then and cut off the flow of stomach content so they cannot vommit in your bood stream ?
How did people get them out before this tool came along ? or did everyone just catch Lymes didease ?
Posted : 26/08/2012 9:19 pm
I found tick tools didn't work on the little ones, so carry tick tweezers now. [img] [/img]
Posted : 26/08/2012 9:32 pm
Bollox.
+1
Although once they are attached you can still contract Lyme or a co-infection without them vomiting.
They have barbs on their head hence why pulling them can leave the head in
Posted : 26/08/2012 9:35 pm
Just spent the past 20 mins looking up how to remove a Tick !
I guess i will be buying some tweazers
Posted : 26/08/2012 9:44 pm
 Taff
I may order one of those cards. Easily stashed in a wallet although don't take a wallet riding with me. My old man used a burnt ember ie cigarette, match etc on their arse an they would just drop off with dying. Did it for years on the farm animals and on himself. Don't carry either of those thins either so of no use
Posted : 26/08/2012 9:47 pm
