LubeTrackWorld - Bl...
[Closed] LubeTrackWorld - Bloody Weather
So I spent a happy evening a couple of days ago going over my bike, cleaning and lubing, checking bolts, that sort of thing.
After thoroughly cleaning the chain I decided, given the fantastic weather we'd been having (and was forecast to continue at that point), to use the trial pot of Squirt dry lube I found in the garage. It's now wetter than an otter's pocket and I'm off to the FoD tomorrow. Should I re-clean and re-lube with wet lube, put wet lube over the dry lube or stop worrying about it and just bloody ride?
Posted : 25/05/2018 9:29 pm
Isn't Squirt considered "universal"?
Posted : 25/05/2018 9:40 pm
No idea.The bottle says to allow drying time before use in wet conditions, but I thought it was primarily a dry lube.
Posted : 25/05/2018 9:52 pm
I think it's meant to dry over night. Take some with you as it has a reputation of being good but not lasting well on a long ride.
Posted : 25/05/2018 10:37 pm
Squirt needs overnight after application to dry.
Its all weather and copes well with mud and wet filth but doesn’t like being frozen and will freeze. There is  a variant that isn’t sensitive to freezing conditions but I haven’t tried it.
Major caveat, squirt doesn’t like traces of conventional lube although it doesn’t mind the OE thick gloop. Applying it to a chain that’s had normal lubes previously applied is going to result in a black mess that doesn’t work well.
Posted : 25/05/2018 10:41 pm
Definatley the last one.
Posted : 25/05/2018 10:47 pm
