lowest stack 1"...
[Closed] lowest stack 1"1/8 standard headset available
[#2220234]
Evening chaps.
What is the lowest stack standard headset available.
i need to fit a new pair of forks but the steerer is a tadge to short.
cheers guys.
Posted : 24/11/2010 6:39 pm
crank bros one is under 20mm
Posted : 24/11/2010 6:48 pm
Thanks stew.
Posted : 24/11/2010 6:52 pm
any lower than this.just had a quick measure and the steerer is 175mm and i need to gain about 30mm
Posted : 25/11/2010 12:21 am
You mite find it easier if you get a smaller stack height stem aswell in that case.
Posted : 25/11/2010 12:28 am
As previously posted Crank Bros Iodine is the lowest.
I had the same problem and tried 4 random stems I had - all had the same stack height - good luck with that one.
Posted : 25/11/2010 12:33 am
What stem are you using? - there is a Truvativ's XR 3D stem that is single bolt and the lowest stack height I could find, when I had exactly the same problem!
You'll ask about steerer length or check next time! 😉
Posted : 25/11/2010 1:12 pm
FSA stems 35mm, Truvativ 32 IIRC, I think there's some super-low machined one.
Posted : 25/11/2010 1:15 pm
If you want one of the low stack Truvativs send me an email I've got one 'cheap'
Posted : 25/11/2010 1:16 pm
 aP
Campagnolo headsets are pretty low stack height.
Posted : 25/11/2010 1:17 pm
 nath
Sunline V1 all mountain stem have a nice low stack height.
Posted : 25/11/2010 1:18 pm
Sunline V1 stems are 34mm
Posted : 25/11/2010 1:29 pm
Headset-wise it is the Crank Brothers one, I've got one and it's been doing it's stuff no issues for 12 months now. Get the DH one, though looking at the designs, they're all the same aren't they? Anyway, the DH weighs **** all, so might as well get that one.
I had the same issue as you, put that headset in and went for a Pro FRS stem, which is pretty low, and ended up needing a spacer.
Posted : 25/11/2010 2:14 pm
My Truvative stem whatever is serpantly lower than a Thomthom.
Posted : 25/11/2010 2:21 pm
Spank Spike - 26mm stack height
Got one on this ->
Posted : 25/11/2010 2:31 pm
M:Part low profile headsets are 24mm if i remember correctly, markedly cheaper than the CB.
I believe the FSA stems are the shortest too...
Posted : 25/11/2010 2:35 pm
