I lost the bolt which holds the lever together, im currently using a screw to hold it together (no great). Has anybody got an idea where i can get the individual bolt from. I have looked over the internet but cant seem to find one.
Which bolt exactly?
I bought spares online because i knackered thr heads on mine using fractionally too small allen keys. Just from memory i think it was ukbikestore. Have a look, come back if yiu have no joy and i'll try and dig out a receipt.
If it's the lever bolt mine kept on falling out of my Formula R1's, I managed to get another one from the shop but was told that the bolts from DMR v12's fit Not sure if they're the same size though.
Its the actual pivot pin which has fallen out, iv tried ukbikestore but cant find anything.
Sorry, i thought you meant the allen-headed bolt with broken thread you use to attach/remove. That was deffo from ukbikestore.
It's Avid bolt, non-split clamp A103830 £2.99.
Your LBS should be able to order it.
Oh, pivot bolt, thought you meant clamp bolt.
Ignore me.
If it's the pivot bolt you can use any old bolt and nut of the same size. The pivot bolt is a plain shaft with a grub screw to hold it in place on the juicy's i had (all 7's tho) and when i lost one I just used a bolt and nyloc nut in it's place. Works fine.
Cheers all for getting back much appreciated.
