Hi everyone,im building lapierre 727 and have frame with inner headtube dimensions 50mm top and 62mm bottom.Ive been looking all around for a headsets and found stock headset from FSA but when i bought it it came apparently 50/62 but was too small,dimensions were for outer rings and wasnt anyhow fit with frame,was just easily popping out.Anyone have any suggestions where can i find one?
Posted : 24/09/2019 12:32 am
How much too small? 50/62 will be the outer headtube dimensions, new 727 lists fsa orbit no.57 which is straightforward zero stack integral tapered headset. If it fits but is loose it could be an issue with the headtube, loctite might sort it.
Check your measurements and the hope tech diagrams
Posted : 24/09/2019 1:48 am
