longshot: clearance...
[Closed] longshot: clearance of a Magura brake booster (see pic)
I'm trying to work out of a big tyre will work with a HS33 brake booster
I need the length of dimension A in this pic
Posted : 26/05/2009 7:40 pm
anyone ?
Posted : 27/05/2009 6:57 am
what boosters are you talking about? I've got evo2's and the boosters. aren't like that - going from the frame forward: there's a backplate that holds the setup rigid onto the mounts, then the brakes, then a 'mini' booster with a minimum of adjustability.
That said, from the top nut / bolt you've 5.6cm. That's NOT from the v-brake mounts but from the top bolt on the brakes themselves. The distance from mount to top of A is approx 10.4cm
There's a fair bit of space in there.
Hope this helps.
Posted : 27/05/2009 7:15 am
cheers for that. Yes the booster I'm on about is the one that bolts across the top of the two brake piston units. As you say, it's a mini booster - it doesn't connect to the frame bosses.
The standard ones look like this, but there are a few variants, which may be taller/lower
Posted : 27/05/2009 9:50 am
OK - mine look like:
The 5.4cm measurement given is from the top bolt upwards
Posted : 27/05/2009 9:53 am
ask on trials-forum
that's the one woffle, cheers
Posted : 27/05/2009 10:04 am
