longevity of carbon...
[Closed] longevity of carbon bikes
say i bought a well known brand of carbon bike, rode it approx 100-150miles per week (more summer, less winter) looked after it and did my best to not crash... whats a rough estimate of its lifespan
Posted : 05/02/2012 12:48 pm
The warranty usually gives a good indication of how long it's expected to last. Some give lifetime/25years (Time,Parlee, etc) But most are 2-5years.
Posted : 05/02/2012 12:52 pm
I'd say warranties are about reputation not anticipated frame life.
As long as you're not doing anything outside its design parameters, shouldn't it last indefinitely?
Who has ever seen a carbon frame break due to fatigue?
Posted : 05/02/2012 12:59 pm
But over time, they go soft/delaminate, you can get water/salt incursion between layers and/or through the resin. the resin might not be uv stable and it certainly wont be corrosion proof and will degrade with water/salt sunlight exposure!
Posted : 05/02/2012 1:15 pm
Does the sky fall in a lot where you live, doctor?
...and how many carbon bikes do you actually own?
Posted : 05/02/2012 1:18 pm
Over time, steel will deteriorate into a pile of iron oxide.
Over time, the Himalayas will be no more mountainous than East Anglia.
Posted : 05/02/2012 1:19 pm
Personally I don't care what you think you know, that's how it is, take it or leave it ❗
Posted : 05/02/2012 1:26 pm
Ah, the 'I have no evidence, you'll just have to believe me' approach. Fool.
Posted : 05/02/2012 1:28 pm
I know of plenty of aircraft wings and cockpits which are still in good order after 20 years! The only cautions were don't drop stuff onto them and wipe off/degrease after severe oil contamination. (Goes to shed to check E120...)
Posted : 05/02/2012 1:30 pm
crikey, I see you don't read very well either!
Posted : 05/02/2012 1:37 pm
I see your inability to substantiate your claims has led you to attempt to duck the issue.
Posted : 05/02/2012 1:39 pm
meanwhile, in the real world, A friend has one of those Lotus superbike MTBs, he bought it new in the early nineties, it cost a small fortune. He had to retire it about 2 years ago (so it lasted 17 years) after a small crack appeared where the front mech was bolted on. He used to ride it in DH, XC and 4X competitions back then and continued riding it up until about 2008. This is a guy who is not kind to bikes and has since written off two frames in the last few years (a Giant Reign and a Kona Coilair). Also bear in mind, 20 years ago carbon technology and particularly carbon bike frames were very much in their infancy.
Posted : 05/02/2012 1:41 pm
Doctor, people who buy expensive steel frames often feel the need to denigrate other frame materials, probably in some vain attempt to justify to themselves that they have made the right choice. I've had custom steel, and aluminium, and carbon. The carbon has lasted longest.
Posted : 05/02/2012 1:53 pm
Aluminium will corrode somewhat, steel will rust and oxidization will creep up on it. so I don't see why carbon is any different to how long it will last in its natural state. Its more prone to unnatural damage in regard to accidents though. I think a carbon frame that suffers a bad off would make me a bit more skeptical on its longevity over a steel frame
All that said though I have seen plenty of Titanium frames with cracks on the tubes and welds even though they may not have had any use more than what they were intended. I have also seen many alloy, steel and Ti frames with bad dents and dings from crashes etc.
Out of all the carbon components a frame would be the one I would have most faith in. I'm not too keen on bars and stems and seatposts made from it for MTB use. A frame would be the one thing I would buy though. I would buy one new though!
Posted : 05/02/2012 2:00 pm
 LeeW
I don't think I'll ever ride anything else but carbon again. I had a Merlin Ti frame which I loved at first. Desperately wanted to beleive the 'hype' I rode a carbon HT and found it far more comfortable. I went out that week and bought a carbon frame.
Be warned though, if you get a single drop of Dot5 brake fluid on the bare carbon, it instantly delaminates and turns the frame in to nothing more than a pile of noodles.
The more you worry about the longevity of a frame or component the less you focus on enjoying the ride.
Posted : 05/02/2012 2:07 pm
For it's last few years it had forks 50mm longer than recommended, survived a massive nose dive off the highest tier drop in Glentress bike park (totalled front wheel and chipped bone in knee) and was thrown in a river to prove it would float.
Posted : 05/02/2012 2:08 pm
I had a Lemond TVT carbon "team issue" frame from the 1990 TDF. They were the early ones that were carbon tubes bonded to alu lugs.
It was still going 19 years 😯 later when i eventually parted with it on e-bay 😥 and it still looked MINT..... 😛
Posted : 05/02/2012 2:09 pm
It'll probably last longer than your ability to withhold buying a new bike. I'd expect it to last as long as any other frame material.
Posted : 05/02/2012 2:11 pm
My parlee has a lifetime warranty, but if i'm honest I won't be keeping it anywhere near long enough to test that. I rather like new bikes, and things move on, 'a bike for life' sounds like a punishment to me.
Posted : 05/02/2012 2:16 pm
Oooh hours and hours. Still see a pre 2000 carbon MTB getting places.
My race bike is a 2007 model which is just having 2012 kit bunged on it.
Posted : 05/02/2012 2:39 pm
why do people forget that carbon fibre is not the only composite material out there. Glass fibre reinforced plastic is probably one of the best examples of how long composites can last, even when not particularly looked after.
Admittedly carbon can have more galvanic problems than glass but it's generally built better as it's a higher cost material.
Posted : 05/02/2012 2:54 pm
I've got carbon fishing rods in excess of 20 years old that are still as good as new. I see no reason why carbon shouldn't have a far superior lifespan (crash damage and misuse excepted) than any metal currently used in frame production
Posted : 05/02/2012 5:35 pm
It's not the lifespan of carbon I worry about it is what happens in an crash. I have riden carbon framed MTB's and they were all lovely but I just won't buy one as I can't justify another bike and I have had the odd off in the past and I would hate to damage the frame.
However if you can avoid the falls carbon firbre composite is wonderful frame material and should last a very long time. The failures you hear about are mostly down to misuse for poor design.
Stability against UV can be taken care of with the right resin's.
Plently of ally or steel frames have cracked in the past through poor design or misuse too. As for the those who put down steel, there is nothing wrong with it. I have four steel bikes and I like them all and if I look after them they will last a life time infact the oldest one I have is a 1989 Marin and that still rides very well. Every material has it plus points and drawbacks. Failure or damage in what otherwise would minor accident is the biggest drawback of carbon I think of.
The carbon bikes I would like is a 29'er rigid SS and a summer carbon road race bike. That would make seven bikes though so I might have to sell some steel first.
Posted : 05/02/2012 6:02 pm
I have four steel bikes and I like them all and if I look after them they [s]will[/s] may last a life time infact the oldest one I have is [s]a 1989 Marin and that still rides very well[/s] as old as the Lotus bike up there, despite the fact carbon technology was pretty shonky back then. Every material has it plus points and drawbacks. Failure or damage in what otherwise would minor accident is the biggest drawback of carbon I [s]think of[/s] have baseless worries about.
FTFY. If you think that steel bikes are indestructible you're rather daft. What makes you think that a carbon bike will explode even if you look after it?
Posted : 05/02/2012 6:16 pm
Ive seen steel primadonna road bikes die when they fall over at a cafe stop and there have been a handful of Ti bikes crack on STW alone in the last month. If your really concerned there was a guy on the weight-weenies forum who mends broken carbon.
Posted : 05/02/2012 6:26 pm
I remember hearing that they degrade 10% over 30 years so they have a very long life span
Posted : 05/02/2012 6:29 pm
what happens in a crash is that you pass the fibres elongation to failure or in the case of some of the one shot heat mould chinese frames overcome the strength of the lap
this remains hidden and then on to catastrophic failure which you guys are such great fans of
As for the longevity of composites I know there's a homebuilt aircraft we built 20 years ago still flying and we didn't know a great deal about a lot of stuff bitd
Posted : 05/02/2012 6:36 pm
roadies used to say that about steel frames, that the frames went soft over a season.. : )
Posted : 05/02/2012 7:05 pm
what happens in a crash is that you pass the fibres elongation to failure or in the case of some of the one shot heat mould chinese frames overcome the strength of the lap, however by that time your metal frame would have also snapped
FTFY 🙂
(I can keep doing this)
Posted : 05/02/2012 7:35 pm
Mine is a 2007 frame - still going without skipping a beat. As I'd be expecting to be honest.
Posted : 05/02/2012 7:39 pm
*adds TheDoctor to the list*
Is there a topic that attracts more BS than carbon frames' longevity? I think not, going by this thread. My own favorite:
seth-enslow666 - Member
Aluminium will corrode somewhat, steel will rust and oxidization will creep up on it. [u]so I don't see why carbon is any different to how long it will last in its natural state. Its more prone to unnatural damage in regard to accidents though. [/u]I think a carbon frame that suffers a bad off would make me a bit more skeptical on its longevity over a steel frame
Erm....1. Carbon is relatively inert 😐 2. WTF is "unnatural damage" and if you mean "crashes" then how can a material alone make a frame more vulnerable to that?
Posted : 05/02/2012 7:48 pm
What did you fix?
Posted : 05/02/2012 7:55 pm
njee20 I think your comments and based on an overinterpreation of my post. I have stated there is nothing wrong with carbon frames. I know steel and aluminium bikes can have frame failures in a crash - I am not daft. I never claimed that steel frames were indestructable you claim I did, a big dofference. Steel, carbon, aluminium alloys are all good frame materials.
I suggest njee20 try reading my post again!
Posted : 05/02/2012 8:00 pm
Coming from a Windsurfing background, carbon masts and booms literally coated in a permanent layer of salt, scraped and dragged along cobbled and sandy beaches. Seems like the least of your worries when it comes to a carbon frame IME
Posted : 05/02/2012 8:17 pm
I'm more worried about carbons galvanic corrosion when next to aluminium! (not wanting to be full of doom!)
Posted : 05/02/2012 10:14 pm
bm0p700f - Member
My C456 has already taken hits hard enough to, if not write off a metal frame, then at least put proper big ugly dents in it. Maybe it'll break in half tomorrow, maybe not 😉
Posted : 05/02/2012 10:19 pm
Giant have a lifetime warranty. I'm on my third 😯
Posted : 05/02/2012 10:27 pm
I've broken several steel mountain bikes at least five alu bikes both road and MTB and a couple of ti mountain bikes. My carbon road bike is the only frame to have lasted more than four years.
Posted : 05/02/2012 10:34 pm
 br
[i]I'd say warranties are about reputation not anticipated frame life.[/i]
The length of a warrenty is purely marketing - and the cost of failures need to be factored into the purchase price.
Posted : 05/02/2012 10:55 pm
Tongue in cheek comment. The crash damage is a completely moot point!
Posted : 05/02/2012 11:12 pm
I've broken a few, 7, (5 road frames , 1 cross frame , 1 FS MTB) plus my current Giant XTC has a very wicked looking paint crack at the seat tube / top tube junction. No creaking at the moment but it's not pretty.
Good to hear about Giant's warranty. Got stuffed on my Colnago EPS as it was in it's 3rd year and Colnago said £440 to fix please.
Posted : 05/02/2012 11:15 pm
Aren't carbon frames generally lighter than steel,alu and titanium ones?
If so and if there was an issue with their longevity and/or strength ,then couldn't they be over engineered to improve this whilst retaining the positive characteristics/feel of carbon and still be competetive weight wise?
Either it isn't really necessary or it's an industry ploy to have carbon bikes fall apart.
Posted : 05/02/2012 11:43 pm
nick1962 - Member
They can- look at, frinstance, the Carbon 456 or a Mojo HD, strong like ox. But road bikes and racy XC bikes tend to go more for lightness.
Posted : 05/02/2012 11:52 pm
Isn't the Carbon 456 still a kilo lighter than the steel one?
Plenty of scope still for making it stronger if needed...but not really necessary?
Posted : 06/02/2012 12:21 am
How, what?
Broke a steel crosser, but it was 35 years old and I was using it on trails.
Posted : 06/02/2012 12:59 am
Looks like the original poster has been scared off...
i am no expert but what I do know is that the term 'carbon frame' can be misleading as it suggests that any one carbon frame is the same as any other... clearly it is not as there are many different lay ups, resins and bonding methods used so each frame will have different qualities and failings.
From my experience the carbon frames I own and have owned and sold have been extremely strong with high impact resistance. That is not to say that I haven't experienced failures but the carbon frames have compare well against steel and very favourably against ally.
In short.... buy the frame that suits your needs based on size, geometry and intended use.... frame material should not really influence your decision as much as the above.
And whatever you do enjoy it rather than worry about it...
Posted : 06/02/2012 2:23 am
I once saw a Trek Carbon Y22 snap spectacularly - the whole seat post arm snapped off. It frightened me a lot because I was 3 feet away on the exact same bike!
No idea of whether it was fatigue though...
Mine was later stolen! 🙁
Posted : 06/02/2012 4:42 am
There's an interview in this week's comic with Trek's head carbon guy and his point is carbon fibre doesn't have a fatigue life however if you do the resin etc. wrong then you can introduce issues that way and shorten it's life. There's also carbon fibre used in aerospace/defence that gets a lot more abuse than bikes and I don't see horror stories about planes dropping out of the sky due to carbon failure.
As for crashing - yeah if you buy a bike made from thick steel tubing it's going to be more impact resistant but who wants to ride around on a something weighing the same as a small car? The common alternative is aluminium and give the walls of a lot of alu tubing I don't get why someone would argue it holds up better in a crash.
Posted : 06/02/2012 9:06 am
How can a material that's impregnated with resin be susceptible to water ingress? And why would salt be a problem to a inert substance like carbon?
Sounds to me like you're taking your limited knowledge of alloy/steel bikes, a few urban myths, a little supposition and basing your arguments on that!
The head carbon guy from Trek is interviews in CW this week, you might want to read it. He has developed carbon for the US military for 30 years. His opinion is that a carbon frame will NOT degrade at all unless it suffers significant impact damage.
 juan
There is two type of carbon bikes.
Scott and the others. I see on a "regular" basis the same 1998 scott endorphin in the workshop of my LBS. Frame is still going strong, in spite of regular riding in the southern Alps.
Posted : 06/02/2012 9:10 am
Easy.
If you overload a piece of carbon it can delaminate, which will allow water in. Whether this will happen on a bike is another thing.
Salt is a problem when mixed with water because it's a conductive fluid, and can cause galvanic corrosion if precautions haven't been taken to prevent it.
Posted : 06/02/2012 9:16 am
I better clarify my post.
Out of the 7 frames, 4 were carbon, 2 aluminium, and the Colnago whilst carbon, failed on the drive side seat stay aluminium dropout.
1) Isaac Force - Chain stay failure
2) Isaac Force - Chain stay failure
3) Isaac Sonic - Seat tube
4) Trek Madone 5.5 - BB shell
5) Kinesis Evo 2 - Chain stay failure (aluminium)
6) Colnago Extreme Power - Seat stay, aluminium rear drop out snapped
7) Trek Top Fuel 9 (2008) - Seat tube crack
The Colnago was the only one that had a catastrophic failure.
Posted : 06/02/2012 9:35 am
Pfft, no one's mentioned osmosis yet? 😉
I reckon the broader scale use of heli-tape will probably help a little for all frame materials. If the external layer of paint/lacquer/clear coat is maintained then the horrible outside world can't penetrate the frame material. Unless you crash. But then again any crash can total a frame.
BMX frames are super tough and fail all of the time, anecdotal evidence only refers to the way that individual used their bike. Then again catastrophic accidents and MTB are quite good friends.
I've wondered how much a sacrificial layer of kevlar or just support strips would add to a carbon frame (when laying up, not after manufacture)?
Posted : 06/02/2012 9:36 am
Treks head carbon guy never invented treks methods this is journalism at it's best yet again
Posted : 06/02/2012 9:46 am
We had a Spark frame we had to destroy (aluminium shock mount cracked). So I hit it with a 1lb ball-pin hammer. Hard. It was fine, repeatedly. After about 10 blows I chipped the lacquer.
Then sawed it in half along it's length, quite interesting.
One blow would've made a big ol' dent in an alu frame!
Posted : 06/02/2012 10:32 am
They are massively over-built, I believe. I weighed my frame at exactly 1500g before I built it (16in) and how light is it possible to build a carbon MTB frame these days??? Sub 1000g easily - 900g????
So in my book that's 50% extra material purely for strength.
Posted : 06/02/2012 10:49 am
Had my carbon seat post snap sending me across the road in front of car. Totally unscientific but put me off carbon for life.
Posted : 06/02/2012 11:01 am
As others have said not all carbon is equal, there are differences in modulus and layup techniques. So it's hard to generalise. As also said above the big issue with carbon is it's relative inability to withstand impacts, particularly "sharp ones", for example the type you would get by hitting a sharp angled rock.
For a road bike or an XC style bike carbon is an obvious choice, IMO for a bike which is going to take more abuse I personally would steer clear.
As an aside, with a little skill and the correct facilities (ie a curing oven) carbon is pretty repairable.
Posted : 06/02/2012 11:07 am
Scale 899 is guaranteed under 900g.
As also said above the big issue with [s]carbon [/s] a bike frame is it's relative inability to withstand impacts, particularly "sharp ones", for example the type you would get by hitting a sharp angled rock.
FTFY - thin walled alu tubing isn't known for it's sharp-impact resistance 🙂
Posted : 06/02/2012 11:14 am
oooops[img] [/img]
Posted : 06/02/2012 11:15 am
Njee, that was almost funny once a few years ago... 🙄
Posted : 06/02/2012 11:17 am
It's a valid point though - not aiming to be funny. People say "carbon's inappropriate, because if you stuff it onto a pointy rock at speed you may crack it". C'mon FFS you really think an aluminium frame will survive that? It's bollocks.
Posted : 06/02/2012 11:20 am
is it that time of month again for the Carbon debate...it comes round quick.
What Njee says
Any frame can break/rust "degrade" etc
The only thing that concerns me with a carbon fibre frame is that it wont dent on impact unlike metal so it may/is harder to tell/judge/assess any effect of the impact.
Posted : 06/02/2012 11:26 am
It's quite comical really, listening to some of the bollocks people "assume" and the urban myths. I particularly liked the "I seem to remember someone saying they degrade 10% after 30 years"... 😀
Even the head honcho of carbon production at Trek plays his cards close to his chest, so what are the chances of a bunch of IT nerds that ride bikes once a week being able to speak with any authority??
As for carbon being "easy to repair if you've got a curing oven", good luck with that! The Trek guy very eloquently explains exactly why carbon frames shouldn't be repaired unless under exceptional circumstances.
Frame tubes are designed to flex in certain directions. If you build up an area with a patch, you affect the tube's ability to flex in the correct way, thus putting excessive loads on the unrepaired areas.
Imagine mending a fishing rod in this way - you'd end up with 2 VERY vulnerable and highly stressed areas on either side of the patch.
As for carbon being particularly vulnerable to sharp impacts? Nonsense. Carbon is THE BEST material to cope with sharp impacts, y'know, like people firing bullets at planes, and bullet proof vests...
It might damage, but it's far less likely to suffer catastrophic failure than alluminium or steel. Fact. ;o)
Posted : 06/02/2012 11:33 am
firing bullets at carbon panels?
Posted : 06/02/2012 11:40 am
Frame warranty is usually about manufacturing defects. Ive been shopping for a new bike recently and many have been carbon and i have been surprused how few years warranty they come with. It's seem about 2 years which is pretty crap.
Somewhere in the admin office there must be a complex mathematic equation that the big bike companies have, something that includes:
frame material + test lab stats - history of customer returns = we can only offer 2 years before the profitability drops below the desired amount.
Posted : 06/02/2012 11:41 am
My 1992 Giant carbon road frame died last year. A crack appeared in one of the aluminium lugs...
Posted : 06/02/2012 11:51 am
compositepro - Member
I believe they use bullets in the theatre of war. And whilst I can't be certain, I would expect some of those bullets to hit the carbon fibre sections of military aircraft and vehicles.
And again, I'm guessing, but they'd be pretty well ****ed if they failed catastrophically after one bullet.
But hey, I'm no expert.
Posted : 06/02/2012 11:55 am
phew... thanks for the replies....
the original post was just to put my mind at rest should i splash out on a new parlee or cervelo frame to replace my litespeed vortex, but seeing as the frame is still in tip top condition i'm hoping i'll not need to... just vanity / buying urge.....
did see a nice vortex on fleabay with a cracking (!) BB crack from weld into tubes...oh i hate pics like that 🙁
now then... you are buying a carbon road frame, you have 2K to spend, what would you go for / or avoid???
Posted : 06/02/2012 5:29 pm
No they don't, it's five years for all Giant frames, regardless of frame material.
I still regularly service 90's Giant CFR team road bike, think it's now on it's 4th groupset & still rides fine with no sign of dying any time soon.
Posted : 06/02/2012 5:38 pm
I suspect some of those bullets might also hit aluminium sections of said aircraft, and you'd be equally ****ed if those failed catastrophically.
Where exactly is your evidence for:
Posted : 06/02/2012 5:46 pm
If carbon is crap, why do some companies give lifetime warrantees?
Posted : 06/02/2012 5:50 pm
aplonker - Member
Erm... The fact that it's the favoured material for making things that need to withstand sharp impacts? 🙄
Posted : 06/02/2012 5:56 pm
You mean like aeroplanes and bullet proof vests?
You don't think there might be some other design requirements for planes?
Maybe you should also check what bullet proof vests are made from.
Posted : 06/02/2012 6:03 pm
You'd think alu and steel frames or bits never fail to hear some people on here.
Posted : 06/02/2012 6:06 pm
I imagine most carbon frames will go aesthetically & technologically obsolete, before they become physically obsolete.
And then you can't recycle it.
Posted : 06/02/2012 6:08 pm
a**** - Member
Possibly, like low weight, structural strength, ease of moulding/manufacture, flexibility, the ability to control flex/rigidity... Absolutely nothing like bikes, eh? What point are you so desperate to make but so unable to put across?
Posted : 06/02/2012 6:11 pm
What point are you so desperate to make but I'm so unable to [s]put across?[/s] understand
FTFY <sigh>
That just because they make planes out of carbon composite and planes have to withstand impact, it doesn't follow that carbon composite is the best thing for withstanding impact.
Oh and <applause> for the ad-hom
Posted : 06/02/2012 6:14 pm
So which material gives the best balance of light weight, impact resistance and flexibility of manufacture?
Actually, don't tell us, go on Dragon's f***ing Den, you'll make a fortune! 🙄
Posted : 06/02/2012 6:26 pm
