Long distance off r...
[Closed] Long distance off roading
[#3971936]
Hoping to do Bristol to Eastbourne, spending about a week. The first part to Pewsey is cycle track and tow path, then it gets trickier.
I'm reasobly fit so thinking 50 miles a day. Doable?
Posted : 14/05/2012 8:02 am
I'd say more than possible but depends on the terrain and conditions. If you can get to Winchester then you can do the SDW route the rest of the way.
Posted : 14/05/2012 8:12 am
that's the plan, sort of wessex way to winchester then SDW
Posted : 14/05/2012 8:59 am
SDW gets hillier towards the end. If you arrive at Winchester with 2 days to go try to do 60/40.
Posted : 14/05/2012 9:02 am
Me and a buddy did it from Weston Super Mare to Eastborne back in 2001.
We used this guidebook- http://www.sustransshop.co.uk/products/5463-wessex-way-mountain-bike-route-pack
Posted : 14/05/2012 9:09 am
That's 1 possibility, but I thought as i live in bristol it would be more peractical to use the track to Pewsey.
How long did it take you?
Posted : 14/05/2012 10:52 am
I'm sure you could adapt the route no problem.
We took a week over it- but I wasn't as fit as I am now.
5 days would be good I think- about 50 miles a day that way.
Posted : 15/05/2012 7:43 am
I rode the Wessex Way in February conditions were awful in some places, enough so that it added hours onto our rides on some days. Although the biggest problem was a lack of training, I was the only rider that put in any effort to train. To the point where the others were completely out of puff 25-30 miles in. It's a nice route though.
Posted : 15/05/2012 8:07 am
We did this the other year, from the other direction. From Winchester we basically headed North across the Salisbury Plain until we picked up the K&A canal path, using bits and pieces of bridleways. The quality of the routes over the Plain was a bit variable and some looked like they'd not been used in years, but I should have a .gpx of it somewhere that I can dig out.
I'd say 50 miles a day is perfectly doable, but be prepared for long days with low average speeds.
Posted : 15/05/2012 9:13 am
Don't know anything about that route, but a good day is normally around 2500m height gain given reasonable terrain. If you have to do a lot of carrying up rock faces, or a total mudfest etc then less than that. The distance normally seems to be irrelivant as long as its around 60-120Km.
C
Posted : 15/05/2012 11:05 am
