Loco etc - fork oil...
[Closed] Loco etc - fork oil and weight question/where to buy?
5wt oil for Lyriks - is Genuine rockshox oil rebranded Torco? Seen somewhere that they use torco 7.5wt for rockshox and claim its 5wt? Its for the damper so semi crucial, the putoline 5wt i have seem shit and is a couple of (damp shed) years old. Shall i just buy some official 5wt Rockshox oil and be done?
Posted : 02/06/2013 8:50 pm
Use this in mine and the damping is spot on.
http://www.ebay.co.uk/itm/Motul-Expert-Semi-Synthetic-Fork-Oil-5w-1-litre-/180804925599
It,s intended use is a bit more that a lyrik can throw at it..
Posted : 02/06/2013 8:54 pm
Rob - what damper are you running?
Posted : 02/06/2013 8:56 pm
http://www.peterverdone.com/wiki/index.php?title=Suspension_Fluid
The now famous comparison chart shows you how the labelling of suspension oils is not exact.... I used Rock Oil SVI 5 which I got from the local motorcycle dealership. It works fine in Revs and Reba, both with MoCo damping
Posted : 02/06/2013 9:07 pm
I have used it in a few.
Lyrik-mission damper.
Rev-blackbox
Pike-motion.
All is good rob.I didn't buy mine from ebay but from a local MX shop.just put the link up as it quite cheap there.Tis wonderful stuff.If it's good enough for MX bikes i don't think our contraptions will foam it up... 😉
Posted : 03/06/2013 9:33 pm
 LoCo
We use the fully synthetic Motul factoryline 5wt in all rockshox damper systems, we also sell it not because it's cheap or we make a good margin but because we think it's the best standard priced oil (a £30 a litre 'racing' oil would be better but then we'd have to charge silly money for a service 😉
Lower oil in rockshox we use 15wt expert semi synth Motul and mix a few other things in with it. But as standard it works very well too.
Posted : 03/06/2013 9:40 pm
Go on Si.What do you throw in it..do tell..
Forget that as i know you perform voodoo magic on suspension so it,s probably the blood of a Haitian virgin.. 😉
Posted : 03/06/2013 10:02 pm
AFAIK - Rockshox now use re-branded Maxima fork oils (Used to be Torco re-branded)
Maxima fork oil from UK based Ditbikebitz.com -
Maxima Racing fork oil £9.98 inc postage for 1 Litre - 5wt, 7wt, 10wt + 15wt.
Standard Maxima fork oil is even cheaper at £7.19 for 1 litre.
[url= http://www.dirtbikebitz.com/maxima-fork-oil-standard-fortified-sae-various-litre-p-26301.html ]http://www.dirtbikebitz.com/maxima-fork-oil-standard-fortified-sae-various-litre-p-26301.html[/url]
Posted : 03/06/2013 10:27 pm
My best local stockist is actually a Ducati dealer - cracking range of Shell oils, and very well priced
Posted : 03/06/2013 10:30 pm
 LoCo
Not telling 😛 if Motul is good enough for K Tech etc it's good enough for us. 😉
Posted : 03/06/2013 10:34 pm
Does that mean iv'e got to keep on buying TF's lower mix for ever then... 😉
Posted : 03/06/2013 10:57 pm
Trouble is, Shell oils are almost double the oil weight of what it says on the bottle, i.e. Shell 5wt = most other brands 10wt!
Posted : 03/06/2013 11:21 pm
How does the motul oil compare to rockshoxs oil's? Are the weights of each similar?
Loco I looked on you site and couldn't see any grease, I need some grease for my SID RCT3's. What would you recommended?
Posted : 12/01/2014 6:33 pm
